Question about Element Electronics Televison & Video
How to change your tv settings from 480i to 480p?
I'm wanting to play oddworld on my xbox, but I want to change the settings to 480p. its currently on 480i, how do i change this? I don't know where to go, or how to change the settings, if anyone knows, it will be very helpful. I've tried to find out how to change the settings on the FAQ in element website, but i cannot find it anyone help please, asap!
  • Element Elec... Master
  • 2,827 Answers
You may not be able to change in in the xbox, because it's your screen that sets that....
Posted on May 07, 2014
  • 15 Answers
SOURCE: want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Posted on Mar 14, 2009
NattyWatty
  • 39 Answers
SOURCE: unclear picture, tv won't change from 480i to 1080p
Try restoring factory settings, most Panasonic TV's have an R-Tune button which means if you enter a menu and press R-Tune it should restore all settings. If the TV cane on 1090p then it should change....
That was a blind guess so I mean sorry if it doesn't work.
Posted on Dec 28, 2007
sandrew
  • 2961 Answers
SOURCE: Getting my Sony TV to operate in 1080i.
Asumming you have set the Xbox at 1080i in the video settings and you have used all the four component lead ends, (apart from the yellow video end, as you won't need this) it should work.
Posted on Jan 11, 2007
  • 55 Answers
SOURCE: How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Posted on Apr 22, 2009
SOURCE: How to change resolution on a Toshiba LCD TV from 480i to better?
Can't solve this problem, because I have the same one! I can say that adjusting some of the fine picture contrrols, like brightness, contrast, color etc help a little. This TV is supposed to go 720 and as high as 1080 I thought?..........
Posted on Jun 08, 2010
How to set display to 1080p on Hisense F42K20E?
You don't. The TV has a resolution of 1920 x 1080 pixels; so it's already 1080p. The number of pixels can't be changed.
What you're probably getting mixed up with is the TV showing the resolution of the incoming signal when you change channels or go to a different source. Standard definition from cable might be flagged as 480i. DVD might show either as 480i, or 480p, or maybe 720p or 1080i or 1080p if you have a scaling DVD player and set it appropriately. HDTV on cable or satellite will show as 1080i or possibly 720p. Blu-rays and PS3/XBox 360 or PS4/Xbox One should show as 1080p when your TV is connected.
Whatever the source signal resolution, the TV will scale it up to fill the panel area of 1920x1080 pixels. So the TV is always using all the pixels, regardless of the resolution of the source signal.
Sep 07, 2014 | Televison & Video
I have a sceptre model x9g-naga v flat screen monitor that I am trying to connect my x box 360 to. It allows me to play games, but when I put in a movie, it says, secure hdcp link not found. I was told...
A simple work around that could be able to fix it is by turning on the xbox, waiting until the screen showed the logo and the error message "secure hdcp link not found" then unplugging the hdmi cable from the back of the xbox and plugging it back in. Of course having to do this each time you wanted to turn on your Xbox would be annoying. (I have not tested this using VGA cable hookup though)
If you are asking how to change your Xbox to 480i then you will need simply use the red, yellow, and white cable as it defaults to 480i. (not possible with your monitor I don't think)
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Console Settings.
  3. Select Display.
  4. Select HDTV Settings.
  5. Select the appropriate screen resolution for your TV or monitor. 480p,720p,1080i,1080p, 1024x768, 1280x1024.
I am assuming from your TV that you are using VGA? With VGA then your system is going to automatically choose the best display for your monitor. You can go into the display settings as described above to adjust your display settings.
Hope this helps.
Aug 02, 2011 | Microsoft Video Game Consoles & Games
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
Analog out of range
Are you playing the game from a computer or a video game system? 800 x 600 res is fine if it's a PC. If you have a video game system, then you have to go into the video game system's menu, ans select resolution of 480i - only on ps3 or xbox, however.
May 26, 2008 | Computers & Internet
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Televison & Video Logo
102 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
