How can I reset the time on my Sony ICF-M770L radio
I just bought this radio second-hand. It worked fine on mains but wouldn't run on batteries. I assumed they were flat and replaced them. Radio now plays on batteries but battery symbol in display has a line through it and I can't reset the time or get any response from the Clock or Time Set buttons.
KaeZoo
  • 156 Answers
SOURCE: How do I set the clock
1. While pressing the BND button, press the DISP button to display the clock display. 2. While pressing the BND button, press and hold the DISP button for two seconds or longer. 3. Press the Left button, then set the current hour. 4. Press the Right button, then set the current minute. 5. Press the BND button, then the clock is set. You can download a user's manual from this link: http://www.clarion.com/us/en/MungoBlobs/615/523/DRX5575(Manual).pdf
Posted on Jun 24, 2007
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
MJS_1
  • 150 Answers
SOURCE: Sony Dream Machine clock radio
0) Read the last answer first :) it is the most likely.
1) Make sure that the noise is electronic, not mechanical,
a) Electronic noise comes from the speaker
b) Mechanical nose originates in the clock
(older mechanical clocks only)
c) Clocks come in 3 varieties:
Electronic
Mechanical "Flip Leaf"
Mechanical "Motor/ Gear" driven.
2) Assuming that your clock is electronic, there are
only two possibilities for causing static.
a) Extremely intense electromagnetic interference,
as in radio waves, from a thunderstorm or a powerful
transmitter nearby, such as a HAM radio or even
an active cell phone.
Intense electro-magnetic waves can be picked up by
internal wires within the radio which act as an antenna,
rectified (demodulated) by internal diodes and transistors,
filtered by internal capacitors and the speaker's inertia,
and still present enough audio frequency energy to the
sensitive speaker coil to be "quite" audible and irritating.
This can happen even with the power off, when the
interference is so strong that it needs no amplification !
This happens to my computer speakers, every time my
cell phone rings, and starts transmitting a return signal.
3) The power switch is intermittently shorting causing a small
amount of DC power to enter the radio, the more intermittent
the switch, the more noisy it gets.
This causes my old clock radio to turn on by itself when its
not supposed to.
The cause of the problem in either in the main power/ mode
switch, or in the clock driven switch or relay.
4) Old switches and volume controls get oxidized with time
and/or bridged by products of corrosion. The simple solution
is to clean them using a good aerosol contact cleaner,
available from an electronic shop for about 10 bucks.
Simply spray the cleaner into all the switches and controls,
while vigorously exercising each switch or control back and forth.
Make sure that you use a safe "electronic cleaner" designed
for the job. It must be safe on plastics, non-conductive, good
solvent and it must evaporate quickly. Don't breath the stuff !!!
Typically the spray will contain TF (tri-fluoro-ethane), or some
other freon substitute.
Freon (Di-fluoro-di-chloro methane) is bad for the ionosphere,
now illegal in most countries for that reason.
Also stay away from Carbon-Tetra-Chloride, which is
VERY toxic.
Do NOT improvise, or use acetone or alcohols, which may (will)
melt the plastic, causing the controls to permanently seize.
Get electronic contact cleaner from an electronics hobby shop.
Good luck. Martin
Please rate my answers.
Posted on Jul 12, 2008
mrgreenz
  • 962 Answers
SOURCE: 2004 saturn vue Replaced battery. Radio and Cd no longer work.
Turn off the car and remove the negative battery cable off. let sit a few minutes then reconnect the cable. try it several times. The removal of the battery causes the computer to deprogram itself. what you will be doing is re-programming the computer module.
Posted on Nov 23, 2008
SOURCE: ow do i set the time of my sony alarm clock with radio?
I just did the trial and error thing. it's okay now. thanks
Posted on Jan 27, 2009
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
How do you reset the time?
hello cheer.... go to this link to see how to set the time
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/ICF-CD831-_E
Feb 26, 2011 | Sony PSYC ICF-CD831 Clock Radio
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Sony ICF-C211 Clock Radio started to display minutes:seconds only instead of showing hours:minutes. I guess, I might have pressed certain combinaton of buttons to start this. Unfortunately, I do not know...
might not be the solution but similar happen me and i went back into time and after awhile found reset,so jus keep trying,if not,turn off unplug for 24 hours and it should flash all zeros when plugged back in,but make sure no batteries in it,lol
Jan 16, 2010 | Sony ICF-C211 Clock Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-7600D Radio side is dead
Getting ready to send it to ACT ELECTRONICS in US.
Mar 02, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
My Sony ICF-SW35 AM/FM/SW Radio is not staying on-
Download user manual of ICF-SW35 Sony Radio from Sony Support and hope this will help you to turn on the unit.
Thank you.
Nov 19, 2008 | Sony ICF-SW35 AM/FM/SW Radio
Time
Indicated the memory is lost, usually this points to back up battery that needs replacing. I do this service.... contact me here .... poikaa(at)yahoo(dot)com
Oct 17, 2008 | Sony ICF-SW77 AM/FM/SW Radio
29 people viewed this question
 Grubhead
Grubhead
