Question about Grinders
What is power rating of Craftsman Professional Variable Speed 8" Bench Grinder poer rating
Power rating
SOURCE: grinder won't stay running
what is the mf(microfarad) rating and the voltage,then go to an industrial electical shopand buy one for the correct voltage and an (mf) equal or greater ,but not by more than 10%---mine cost $9.00-in Maine---good luck- MATT
Posted on Jan 04, 2009
  • 2692 Answers
SOURCE: looking for parts for variable speed grinder
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001sj
Posted on Feb 28, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Posted on Dec 28, 2009
Testimonial: "Great solution. Yhank you. - b"
  • 52 Answers
SOURCE: I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Posted on Mar 02, 2010
Variable speed grinder model 315.17340
that comes up as a craftsman brand by sears ( mass produced )
I cant find an exploded view or user manual
if you cant get the value information
think you will be up for an oscilloscope
Jul 03, 2016 | Grinders
Looking to replace obsolete switch on Craftsman 1/2 hp bench grinder. Sears lists part as 4984992
This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
Dec 12, 2015 | Craftsman Grinders
Porter cable
DO NOT leave it that way - that fuse is for YOUR protection, and the protection of your family and neighbors.
That humming is probably an byproduct of the speed control, not too much to worry about. The vibration should go away almost entirely when you reset the wheels to run true and dress them to balance.
The capacitor is your starting capacitor - its voltage rating is completely unimportant - that's a max voltage rating, and they only wanted to stock one capacitor, not have one for the 120V versions and a second one for the 240V versions.
Did you by chance start working on this grinder while it was still under warranty?
If the wheels turn freely when the power's off, and if the grinder doesn't get awfully warm when it's in use, then I'd think that the problem is within the speed control board.
Feb 10, 2014 | Grinders
I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
Mar 10, 2011 | Delta ShopMaster 8in Grinder with Light...
No motor replacement for 152.217060 6 1/8 planer
You are correct, there is no replacement for part # OR90357, but if you have the original motor, I am sure that a local electric motor repair shop will be able to repair, or replace it. I'm confident that this is your best option at this point.
Nov 25, 2010 | Orion Craftsman Professional 8 in. Bench...
Smoke comes from around the switch when turned on & is slow to turn initially. mine is a fixed speed
If it is under warranty, take it back. If not then it is a simple matter of replacing the switch. Take off the cover and pull out the switch. Mark each wire as you take it off. Take the switch with you to the store. First try a hardware store, then an auto parts store. If they don't have it try Sears. They will probably be able order it. Make sure you have the model number of your grinder. It is on a data plate somewhere on the grinder. If Sears can't get it, try a wholesale electrical parts house.
Nov 19, 2010 | Orion Craftsman Professional 8 in. Bench...
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Grinders Logo
138 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Are you a Grinder Expert? Answer questions, earn points and help others
