I have a flat screen Samsung TV, I am not sure what my son sprayed on our TV as he said he was cleaning it, but now it turns off and on. I am also not able to change the channel or volume. It is stuck on DVD mode and thats all we can do is watch dvds until it powers off. Is there a way to fix this
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
You need to qualify what was sprayed. Try using a mild isopropyl mix and an air duster can. Who knows if thatll help. Depends on what was sprayed and where on the unit.
Posted on May 06, 2014
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Posted on Apr 28, 2008
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
Neoklassic1
  • 70 Answers
SOURCE: Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Posted on Jan 31, 2010
How do I clean my lg screen on my tv properly
Hello
Buy one Bottle of Monster ScreenClean Home & Office Display Cleaner
Make sure your TV screen is completely cooled before cleaning. Have TV turned off for about 30 minutes before cleaning to allow screen to cool off. Unplug TV. Make sure the area where TV is located is well lighted. This will make it easier for you to see if you are leaving any smudges behind when you clean your TV screen. I suggest you get a Monster ScreenClean Display Cleaning Kit, unless you have a couple of clean and quality Microfiber cloths in your home. If so, you can buy the ScreenClean solution separately. Some LCD TVs come with a Microfiber cloth, but they are usually a bit small
Spray Monster ScreenClean to Center of TV
Assuming you are using the Monster brand display cleaner, remove the little plastic cap on top of the bottle pump. Please do not try to go cheap with display cleaning solution when you most likely have a not so cheap TV. The cleaning solution will be much cheaper than having your screen repaired or replaced. The Monster directions state to either spray the ScreenClean solution onto the Microfiber cloth or directly onto display surface. Although the Monster solution is drip resistant, it does trickle sometimes, although very slowly. For that reason, I suggest if you are going to spray your screen directly with the Monster solution, spray toward the center of the TV screen about 8 inches away from the surface. Do not worry, if you forget and spray the solution closer to the frame of the TV, the display cleaning solution is still rather slow in to trickle down your screen. Just use a little caution
Gently rub Microfiber cloth in a circular motion to apply the cleaning solution evenly over entire display. Repeat with dry portion of the Microfiber cloth if the TV screen needs extra polishing. You may get a smudge free cleaning without the dry portion of your cloth if your TV screen was not that dirty
To clean the frame of most LCD and plasma TVs use a clean eye glass cloth dampened with water. Make sure to go in one direction around the frame of the TV. Check manufacturers directions to be certain, but for most the eye glass cloth should be fine. Since it is made to take care of eye glasses, it does not scratch. For certain it works fine on the Samsung Touch of Color TV frames
May 13, 2011 | LG Televison & Video
We have a denon avr-589 5.1 system. It worked great until my son tried to hookup the wii into it. We now have no sound on the tv and dvd player. He normally plays the wii through the samsung flat screen...
foxtile,
How funny my son just did the same yesterday!
Make sure that the speaker selectors and the input modes are set correctly. He must have hit both buttons at the same time which turned off the speaker outputs and changed the input mode to a setup we were not using.
-Chris
Jan 09, 2011 | Audio Players & Recorders
I have a 40 in samsung lcd and i have smudges on the let part of the screen and i have cleaned the surface but it is still there so now what
My son sprayed febreez on my samsung flatscreen and now there is a translucent black wipe mark/shadow under the screen. Is there anything i can do to fix it?
Feb 18, 2010 | Samsung LN32A330 32 in. LCD TV
What do I clean the TV screen with. It has smugges and smoke on it. thank you.
Use extremly lightly damp lint free cloth. Don't rub too hard. Or buy screen cleaner in local TV sales stores
Dec 03, 2009 | Samsung LN46A650 46 in. LCD HDTV
My toddler has put toothpaste on the screen of our Samsung TV LCD HDTV LE40F71B, what is the best way to clean it off?
Monster Cable Screen Clean.
(you can buy it at every major electronics store)
http://www.monstercable.com/productdisplay.asp?pin=2350
Oct 09, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Samsung plasma tv shows no picture after cleaning
u may have a bad y-sub board , it is normal on plasmas
Mar 29, 2009 | Samsung SP-S4243 Television
Wrong Chemical Cleaner on 60 inch DLP TV
Hi There,
Unfortunately, I think you may be out of luck. If you spray a screen directly you are taking a chance at killing your TV. You're actually pretty lucky that it still works. Some chemicals can eat right through or seep through edges and corners and ruin the life of your TV. I am not sure if Mr Clean contains alcohol, but that is the last thing you want on any screen. I would suggest trying to clean it off with an alcohol free solution for HDTV screens only or calling Mitsubishi immediately and see what they have to say.. Here is a similar product for what I am talking about:
http://www.meijer.com/WireLogic_CleanScreen_690020200.pro
Good Luck and Happy Holidays..
Dec 23, 2008 | Mitsubishi Televison & Video
Cleaning samsung big screen television
sorry for the cut off chat. this website crashed my computer.
enough said,
the manual is here.
There are instructions on how to open the TV.
Aug 24, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
