Question about Kenmore Refrigerators
Manual or kenmore 596.75232400
I am having problem with the board. I need the diagnostic instructions and installation procedure of a new board.
    Novelist:
  • 150 Answers
What type of problems are you having with the fridge? Your board is located behind the top center unit where the touch panel is. It's called a Jazz control. Programming instructions are usually included with the new part, the new part will not work unless it's properly programmed to the correct fridge via the "Code" number located on the model/serial sticker inside the unit. There are multiple diagnostic modes to test carious parts of the unit. The most common failure is non defrost of the freezer caused by the Jazz control, I have also witnessed a simultaneous operation of scheduled defrost, and cooling as the compressor relay points were fused together. Pleazer Appliance...
Posted on May 07, 2014
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
Kenmore dishwasher
Kenmore appliances are made by many different manufactures and depend on manufacture there are variety of resetting procedure
In some models If turn off your main power to dishwasher for one hour or so and then turn it back on. It should reset itself other wise it seems like it is in need of new control board
Dec 09, 2013 | Dishwashers
We are renting a new place and the previous owners did not leave the instruction manual for the frigidaire self cleaning convection oven. we were cooking dinner tonite, and when i went to check it, the...
Possible cause: inlet valve, pressure switch or control board failure.
Possible solution: Do not open door, select drain/spin to remove water, restart cycle.
I also found a listing that says e45 is a bad control board.
I would look inside the washer for a wiring/diagnostic sheet that will give the test procedures.
May 14, 2011 | Kitchen Ranges
I need the service manual for a model 911.49489992 Microwave. This oven is part of an oven/microwave unit. I have ordered the magnatron but Sears did not have the service manual or instruction sheet for...
I am assuming the case from the microwave has been removed.
Ensure the capacitor is discharged!
Remove the connections from the rear of the magnetron and remember which way around they go, a photo on a phone camera is very usefull!
Undo the fixing screws and remove the magnetron from the cavity. Replacement is the reverse procedure.
Hope that helps.
Nov 06, 2010 | Kenmore Microwave Ovens
Kenmore HE5t elite washer will not start...lites come but door lock lite will not come on so machine will notstart. model # 11047081601. I changed the computer and the door lock switch assembly Will
You might have a problem with either:
  • the control panel board: "start" button may be malfunctioning.
  • the pin on the door may be broken
  • there are 4 electronic control boards in this washer, and they're not so easy to check. Find the tech manual, it should be either behind the cover underneath the door or behind the top cover, diagnostics procedures should be described there.
Good luck.
Mar 13, 2010 | Washing Machines
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Nov 21, 2009 | Kenmore 500 6952 Dryer
Strange noise when doors are closed
Is it the Kenmore French Door model made by by LG?  I have the similar LG refrigerator since 2/2007 and have had several problems with it.  The sound you hear may be  a fan motor that is failing or freezing up.  The noise will stop when you open the doors because that shuts off the fan motors. In the last two years I have had the refrigerator fan, the air channel duct, the mother board, the ice maker fan, the ice maker duct and the mother board (again) replaced (under warranty, fortunately).  After the first service call I installed a power surge protector since a component on the mother board was fried.  I think the second mother board replacement was due to a software change related to the ice maker issue.  There is also a case related to LG Energy Star ratings (that includes the Kenmore made by LG) that you can register for that is supposed to make free modifications and an ongoing rebate payment for as long as you own the refrigerator.  I found an LG service manual PDF on line (search by model number) that has diagnostic codes and test procedures that is very helpful when I need to troubleshoot and communicate with the repair shop.
May 19, 2009 | Refrigerators
Kenmore F-01 error
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Good Luck!!
Thanks
Apr 22, 2009 | Kenmore HE2 Plus Front Load Washer
Fridge won't make ice
There is an optics test procedure you can perform on your own to confirm what the repairman says. Assuming you have a whirlpool-made Kenmore (if you have a Pur water filter at the bttom left of your unit, you do), see here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Basically, the icemaker won't initiate a harvest (dump) cycle unless the electric eye through that cutout at the top of your icemaker can see across the top of the dispenser. If the lens is dirty, or if either the emitter or receiver boards are bad, the optics won't connect. There's a simple diagnosis procedure in that pdf above. Since your fridge is from 2005 like mine, refer to the "post 2002 redesign" optics procedure. Basically the test is to open the fridge and look at the LED, then to close the flapper on the left wall of the freezer and see the change in LED behavior. This can confirm or deny an optics issue. Also, if you remove the little plastic grille at the bottom of your fridge, there'll be a piece of paper folded and stuffed in there with the diagnostic procedure in it as well. To do the full diagnostic procedure, you'll need to remove the icemaker and install a jumper, but to debug optics only, all you need to do is open the door, close the flapper, or maybe push in the door switch and look at how the LED responds.
Mar 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
