Question about Apple iPad Tablets & eReaders
How can i reset my eviant ipad
I forgot my passcode and i cant remember it
  • 59 Answers
SOURCE: im trying to unlock the home screen of my ipad, i
Unfortunately, you're a bit stuck. The only way of removing a passcode without knowing it is to restore from an iPad backup when the passcode wasn't applied.
My advice would be to take it to an Apple Store, and explain the situation. They're always very helpful, and may be able to do something about it.
Hope that helped!
Posted on Mar 06, 2011
ejkudelka
  • 1188 Answers
SOURCE: cant remember my passcode how
The following procedure details the process to Hard Reset your NOOKcolor device. Doing so will perform a factory reset of the NOOKcolor which de-registers your device as well as erases all local content such as contacts, sideloaded documents, personal information, 4 digit passcodes, etc. 1.Ensure your NOOKcolor is powered off; to do so, depress the power button for 5 seconds. Your LCD screen should turn off
2.With your NOOKcolor powered off, Hold the Home Key (NOOK "n," logo below the LCD), while simultaneously depressing the Power Button for up to 25 seconds.
3. Your NOOKcolor will begin the start up process, Do NOT let go until a confirmation window appears asking if you would like to, "Factory Reset Your Device?" This will De-Register as well as erase all content and information on your NOOKcolor (Including the 4 Digit Pass-code
4. Depress the Home Key to continue with the Factory Reset
5. Depress the Home Key again to Confirm
6. Your device will now begin the clearing process. Upon completion you will regain access to your NOOKcolor however all account and personal information (email, contacts, pass-code, credit card, etc..) will be deleted from your device. You will then be able to Re-Register your NOOKcolor and start anew. Good luck!! EJ Kudelka
Posted on Sep 07, 2011
  • 1099 Answers
SOURCE: cant remember my passcode for my ipad
plug it into the original computer that you set it up with and through itunes you will be able to reset it. Once the ipod appears under devices click on the restore button it will indicate that you can restore settings etc. If it is not the original computer that you are using you will be able to reset it but will lose the information on it. Hope this helps.
Posted on Nov 22, 2011
  • 19 Answers
SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Posted on Dec 08, 2011
  • 32 Answers
SOURCE: How do i reset my locked iPad?
if u r having software of that i pad u can use it with datacable and then format it
Posted on Aug 27, 2012
Passcode is required to enable Touch ID on Ipad
This is plain and simple - you need the original passcode before you can add your fingerprint. If this was a used tablet - you can get the passcode from someone that has it - or you may be able to factory reset it using itunes and recovery mode.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Apr 27, 2017 | Tablets & eReaders
Moved house. Did not turn on the ipad for two weeks. Battery was flat. Tried to turn it on and it asks for a passcode. Have typed in my passcode, but it does not recognise the code.
That's very odd.. You are sure you didn't put the code in wrong or remembered it incorrectly?
If you forgot the code to your iPad you may have to reset it to factory defaults by plugging it into your PC unless you have a backup you can restore.
Aug 17, 2016 | Apple iPad (16 GB) WiFi Tablet PC
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
Set it up with thumb print when Iopened it up wont let me in without 6 digit passcode which I don't have
Well, when you first set up your IPad you had to create a passcode to get in. If you can remember what your passcode is click the link here and reset it. Forgot passcode for your iPhone iPad or iPod touch or your device is...
May 21, 2016 | Apple iPad Tablets & eReaders
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Sep 21, 2015 | Apple iPad Mini
Forgot passcode
The solution to this problem will result on the deletion of all data. Turn off your iPad, then, connect your iPad to your computer while pressing and holding the home button. Let go of the home button when your iPad says, "Connect to iTunes," and then restore using iTunes.
Mar 13, 2014 | Apple IPAD2 Tablet/WHITE
Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Apr 03, 2013 | Apple iPad Tablets & eReaders
How do i reset the passcode
If you forgot or lost your password for your iPad, you'll have to restore the iPad. Plug the iPad into your computer using the cable, and open iTunes. Click on your iPad in left pane and click the 'Summary' tab. Click 'Restore.' This will wipe all data from your iPad and effectively reset the device to factory settings, but it's the only way to reset the passcode.
Feb 26, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
14 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
