Question about Mtd 19 In. 173 CC OHV 3-In-1
How much oil to fill a MTD Gold push 3in1 173cc mower
I just changed the oil and don"t have the owners manual, how much oil to refill.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Mtd Master
  • 1,313 Answers
Should be a a dip stick on the end of the filler cap with a gauge
Posted on Jan 31, 2018
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
  • 332 Answers
SOURCE: where do i change the oil on 5.5 hp. 21 inch cut
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Posted on Apr 04, 2010
  • 61 Answers
SOURCE: where to find manual for MTD for gas 4.5HP mower
Try going to...................MTD.com/manual
Posted on May 09, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a mtd 6 hp push mower,what type of oil
Lawn mowers with engines smaller than 10 hp use a "splash" oil system for lubrication. Therefore you should use a standard SAE 30W non detergent oil. Per most user's manuals oil changes are every 25 hours of use. Every 4th oil change you can use a detergent 30W oil. Doing this will clean the inside of the crankcase and all components to the point the look brand new. It will not hurt the motor or the seals in the motor. However after this cleaning 25 hour period with the detergent oil, you should go back to SAE 30W oil again.
Kelly
Posted on Jul 20, 2010
My mtd gold will not move it is a hydro and wont tram eather way
Robert, check the hydro. release lever at rear of tractor, if you can push tractor the lever is in release mode and has to be switched to engage mode. If this is not the problem it could be numerous things, broken/stretched belt, fuse for clutch blown,faulty clutch, park brake stuck on, broken shear key in transaxle or damaged, gear linkage loose, if any sign of hyd. oil leak check level/fill and bleed as per your manual,etc. You may want a good small engine tech. to have a look, diagnose and estimate repair.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Owners Center
Video Troubleshooting Tractor that Won Move
Lawn Tractor will not move forward or backwards ShopYourWay
http://support.mtdproducts.com/app/answers/detail/a_id/97/related/1/session/L2F2LzEvdGltZS8xNDcyMzk0MzQ2L3NpZC8yb3hyUmNabQ%3D%3D
Aug 28, 2016 | Mtd Garden
Key will not work on ignition.
it has and oil safty switch on it you will have to push it to some flat ground to start it you will have to wait to start it let the oil settle down to level dont leave lawn mower on a hill it will happen every time
Aug 16, 2014 | M T D Products Mtd Gold 50"" 25 Hp Zero...
How much oil do I put in my Mtd Gold self propelled mower
most push mowers are about a half a quart
May 11, 2012 | Mtd Garden
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
I just filled up my oil resevoir with gasoline (containing fuel stabelizer) on my MTD 22in. 4.5Hp lawn mower. Ive drained out the oil & gas mix & dont know what to do next before i refill it with...
you need to get all the info on the motor, its not an MTD motor, most likely Brigs & Stratton. Then go to their web page for an online manual. Most companies post them
Mar 06, 2011 | Mtd Garden
I have a mtd 6 hp push mower,what type of oil should i use for it?
Kelly
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
What weight oil is used for the MTD 21" Yard machine> I need to add oil and I wnat to make sure I add the right kind!
Your Engine is more then likely a 3.5-4.0 hp so use 5w30SAE oil do not add my suggestion is to change changing will keep you from over filling and causing an air lock in the Lhead if you were to get an air lock you will blow out your Lhead gasket. So better safe then sorry change don't add ok of course this is my opinon I am no pro I have just learned from my mistakes.
Apr 17, 2010 | Mtd 22" Yard Machine Push Mower
Changing oil in my mtd lawn tractor!! Was oil should I use? Where is the filter? How do I change it?
Most Mower engines have an oil drain plug located at the base of the oil fill tube or dip stick tube, Most mower engines use a standard 30wt engine oil, however, to stay within the parameters of your warranty, use the manufacturers reccommended oil, this info can be located in your owners manuel.
Apr 14, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
I'm looking for owners manual for a 1997 Wizard riding tractor.
If it is an MTD tractor try going to www.buymtdonline.com and there is a section for manuals. Click on manuals and follow the instructions.
Let me know if this helps.
roundo4
Aug 07, 2009 | Mtd Gold 42" Zero-Turn Mower -
Oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Nov 22, 2008 | Mtd 22" Yard Machine Push Mower
Mtd 19 In. 173 CC OHV 3-In-1 Logo
201 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
