Question about JVC Televison & Video
Need code for motorola dct700 to program cable box output on jvc vcr
  • 520 Answers
SOURCE: VCR/Cable TV Connection
The cable should be connected to the antenna in jack of the VCR. The out to tv jack should then be connected to the antenna jack of the tv. When the VCR is in "vcr" mode (tv/vcr button) you should see it when the TV is tuned to the output channel of the VCR (usually ch3 or ch4).
Posted on May 24, 2008
SOURCE: Emerson Jumbo Remote Code for Motorola Cable Box Needed!!!
I just used 051 with the giant emerson remote and a motorola cable box. It worked right away. Good luck.
Posted on Dec 28, 2008
SOURCE: Unicersal Remote code for Motorola cable box
I found this on another site: It works BUT you don't have all the functionality you would have with the cable remote (of course). If you want power on/off, vol up/down and channel change.. this is your fix.
Was this comment useful?
new Starbox("rating1496612", 0.0, {identity: 1496612, stars: 5, buttons: 5, max: 5, total: 0, onRate: saveVote});
  • Motorolla Comcast code Posted by whowlett5 on Dec 26th, 2008 at 12:40pm
    I got mine to work using the Code search method. The manual is incorrect though about using the code search: Instead of pressing Power repeatedly, you just press it once. It sequences through the codes. You then need to press Enter immediately when the comcast unit turns off.
  • Posted on Jan 14, 2009
    MNfisherman
    • 11896 Answers
    SOURCE: need code for motorola cable box with a insignia remote
    Assuming you have the DRC800 remote:
    Codes are 0467 or 1376
    You can EASILY program the remote without a key code:
    1. Press the "cbl" button
    2. Press and hold "setup" button Until red light blinks twice
    3. Press 9-9-1
    4. Press power button
    5. Press chanel up repeadedly until your cable box shuts off
    6. Press "setup" button again
    That should be all there is to it. You can do the same thing for TV,VCR/DVD,Audio, whatever
    It's easier than it looks.
    Here is a website with more info if you need it:
    http://www.eastlink.ca/cable/support/documents/DRC800_User_Guide.pdf
    Posted on Jan 17, 2009
    greenspan
    • 1734 Answers
    SOURCE: Need the cable box code for my Mitsubishi HS-U270
    Ask http://manualfox.com/remote.htm
    They already found the codes for Motorola cable boxes.
    Posted on Aug 26, 2009
    DCT700/US - Unable to turn on with remote. Yellow light flashes on then off to brief red light then nothing. Tried removing cables and plugging in to power outlet only, but same result.
    it sounds like the box is working proper... just needs to wake up. the remote may be your problem.
    God Bless Motorola For Giving Us Cable Boxes With No Buttons!
    ok, does your remote have lights that flash when you hit buttons?
    for example pushing volume lights up tv. if the cable light doesn't flash then it may need reprogrammed. if none of this applies to your remote... sorry
    good luck
    Sep 06, 2011 | Arris DCT700 DTV Receiver
    I need help programing the VCr to record now that his receiver has been added.. is there a how to manual somewhere? thank you
    Hi
    here it is..pls visit the URL below for downloading your manual..
    Hope this helps! Take care and please Remember to rate/vote
    and give me 4 Thumbs Up for me to continue for Helping out the Community :)
    Thanks
    Motorola DCT700 All-digital Set-TOP manual download File size: 840 KB
    Document type: User guide, user manual
    http://www.chung-sim.com/motorola.dct700.all-digital.set-top.html
    Jun 25, 2011 | Arris DCT700 DTV Receiver
    My Motorola dct700 is turning on and showing the guide page but says channel should come on soon had been this way all day, nothing wrong with the cable trying to get it on rather than waiting for tech. I...
    This only happens under 2 conditions. 1) you are not getting signal or 2) the box is bad. Now if you have cable in the rest of the house it could be a glitch with that box. Sometimes the box doesn't communicate to the cable co or vice versa. By resetting I'm assuming you disconnected power from the wall and waited over a minute. A call to the cable co will be needed to resend a signal over the line to activate it. Some cable co can even do this by an automated system. If the box is bad, well you gotta call them anyway.
    Apr 08, 2011 | Arris DCT700 DTV Receiver
    I need the list code for a jvc television
    Here are the JVC codes. 012,024,036,037,040,048,051
    Programming a Device using Code Search:
    Manually turn ON your device (TV, VCR, Cable Box)
    Press and "HOLD" CODE SEARCH
    Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
    Release CODE SEARCH.
    Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
    Once the device turns off, press and release ENTER.
    With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
    Programming a device using the Code Lists:
    Find codes for each device and brand below.
    Press and "HOLD" CODE SEARCH.
    Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
    Enter the three digit code from the TV, VCR or Cable Box code lists.
    With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
    GOOD LUCK!
    Oct 17, 2010 | RCA RCU403 Remote Control
    DO THE DCT700 CABLE BOXES HAVE AN TV TUNER BUILD INSIDE THEM?
    RTFM!
    • MPEG-2 digital video processor
    • ATSC standard Dolby® Digital (AC-3) Audio Processor
    • ITU standard 64/256 QAM/FEC enhanced adaptive equalizer
    • On-board real-time RF return (256 Kbps)
    • Bitmapped graphics display (4-/8-bit)
    • 90-860 MHz Tuner
    • DES-based encryption DCII access control
    • Digital diagnostics
    • Frequency agile 2.048 Mbps out-of-band data receiver
    • Macrovision copy protection
    • IR support for remote control
    • RF remodulator output (ch. 3, 4)
    • Baseband video and audio outputs
    Jul 20, 2010 | Arris DCT700 DTV Receiver
    Remote Codes for Motorola Cable Box DCT700/US
    I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
    If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
    Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
    Good Luck ....
    Jan 04, 2010 | One For All URC-9800 LCD Remote Control
    I am trying to connect the vcr to the tv with a cable box
    There are two ways to connect your equipment.
    1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
    2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
    Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
    Mar 30, 2009 | Hitachi Televison & Video
    Need codes
    Unit does not have a manual, but I did find this -
    For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
    1. Manually turn ON your device (TV, VCR, Cable Box)
    2. Press and "HOLD" CODE SEARCH
    3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
    4. Release CODE SEARCH.
    5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
    6. Once the device turns off, press and release ENTER.
    7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
    1. Find codes for each device and brand below.
    2. Press and "HOLD" CODE SEARCH.
    3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
    4. Enter the three digit code from the TV, VCR or Cable Box code lists.
    5. Release CODE SEARCH.
    6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
    Let me know if this works, and if not, I'll keep looking.
    Feb 01, 2009 | JVC DR-MV100B DVD Recorder/VCR
    Remote code list
    JVC DVD 0558 0623
    Motorola Cable 0476 1106 0276 0810
    Mar 06, 2008 | JVC RM-C18G-1H Remote Control
    Televison & Video Logo
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
