Question about Dishwashers
I cannot turn the "retractable" feet at the rear of my ProLine dishwasher.
The feet are threaded only on one side (so the cross-section is slightly more than semi-circular, with a flat face). There is a white plastic surrounding them as they enter into the dishwasher, so they will not turn to retract. But I can't find the release mechanism and I need to get this dishwasher out. To do that, I need to retract the feet. Help!
  • 957 Answers
I DONT KNOW IF THIS WILL WORK FOR SURE BUT U COULD TRY BREAKING THE WHITE PLASTIC AND TAKE IT OUT OF THE WAY AN SEE IF THEY WILL TURN TO LET WASHER DOWN.
Posted on May 07, 2014
4 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: I have a white Asko model 1585 dishwasher. I need
Hello, sue
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
elstretchie
  • 140 Answers
SOURCE: 3 loose plastic rings found in primary filter
what you are describing is known as an 'olive' the sealing part of a water union known as a kinko and olive, i would nt worry to much they have been caught by the filter and it is just doing its job ....unless of course there is a leek then you will need to find the unions they came from
Posted on Jan 16, 2009
ercupa190
  • 12223 Answers
SOURCE: Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Posted on Jun 14, 2013
Is the cross member under the load
cross members are the chassis members that tie the side frame rails together. There will be one at the front and another at the centre of the chassis and one at the rear . There is a bolt in cross member at the rear of the gear box (rear engine mount). Most modern cars are uni-construction (that is the body is complete and the front section will have a front cross member and the sub-frame rails will be bolted under the body around the front door pillars and onto the fire wall.. IN heavy vehicles there is a front cross member the carries the front engine mount another after the gear box to carry the cabin mounts and then a member every 3-4 feet to the end of the chassis rails . Their only purpose is to tie the chassis rails together.
May 03, 2014 | 1989 Chevrolet G20
Adjusting rear feet on a beko dishwasher
if they are threaded then there may be a lock nut to loosen off before you can turn them
if they are not threaded then they will not be adjustable
Nov 17, 2012 | Beko Dishwashers
My dishwasher electrolux esl6115 is leaking from the bottom of the door during the cycle.
My dishwasher electrolux built in unit was leaking, turned out to be the plastic nut inside on right hand side where water feeds the top rotar was loose. I actually took side off and found it running down inside and flooding out the feet and sides. Solution in my case was to wrap PTFE around the threaded section and rescrew nuton tightly..Problem solved. Simples.
Nov 15, 2010 | Electrolux EDW5505ESS Built-in Dishwasher
2006 Kia Spectra 5 rear brake disc replacement
One side,turns right,and push in slightly,and the other side turns left,to retract.
Apr 20, 2010 | 2007 Kia Spectra5
I am going mad here looking for a pdf manual for a PROLINE DWF1250P Dishwasher.someone somewhere must be able to help..dishwasher not finished its cycle,not much in bottom,cannot get it to do any thing...
I found this link for a Haier DWF1250P when I searched for Proline. It is a free download so get it and see if it applies to your dishwasher. Look for the tiny letters on the left side of the page next to where the photo should be.
http://www.retrevo.com/s/Haier-DWF1250P-Dishwashers-review-manual/id/1236ag304/t/1-2/
Mar 31, 2010 | KitchenAid ProLine
How to collapse rear brake calliper on a 2005 cadilliac deville. I am using a c clamp with pressure and it wont budge with the bleeder cracked open
The rear caliper piston,turns in,with slight pressure on it,one side will turn right handed,to retract,and the other side will turn left handed to retract,the auto parts store sells the tool to do this with,it is a square tool,for sides,with different combinations of pins that will fit the caliper piston for your cadilac.The tool fits on a 3/8 ratchet,I hope this helps you,thank you.
Nov 14, 2009 | 2005 Cadillac Deville
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
    Fixing a leaking door
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    I need an operation manual for a proline logic dishwasher
    1. Download User Manuals | eSpares Proline EF9000B/1 Spares & accessories for this model. No user manual available for this model. Proline EF9000B/2 Spares & accessories for this model ...
      www.espares.co.uk/usermanuals.aspx?c=1084&ma=1169&mo=451471&sa=1 - 50k - Cached - Similar pages
    2. how to mend it .com - problemswith proline logic dishwasher? Other users of howtomendit.com provide the answers. ... Proline logic dishwasher all the lights are flashing and it will not fill or empty what is the ...
      www.howtomendit.com/answers.php?id=196053 - 58k - Cached - Similar pages
    OR CONTACT THE COMPANY DIRECTLY AND ORDER ONE
    Apr 30, 2009 | Dishwashers
    Frigidaire Ultra Quiet 111 - ground up dirt on dishes
    Remove the bottom plate near the floor. You can then look in under the dishwasher machine. The feet are adjustable up/down with a wrench most of the time. The dishwasher machine should tilt slightly away from the over flow sensor. In this case, Frigidaire Ultra Quiet, the rear feet should be lowered, or the front feet raised. If you have a machine with the over flow sensor on the bottom, at the back, tilt your machine slightly forward. Use detergent that dissolves food proteins. Problem solved. If you care to reward me, put a small symbolic sum to paypal account carolehel@aol.com
    Feb 07, 2008 | Dishwashers
    Dishwashers Logo
    46 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
