Question about Fedders A&B Chassis A1A07W2B Air Conditioner
Galanz fan and compressor keep shutting off - Fedders A&B Chassis A1A07W2B Air Conditioner
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
Galanz air conditioners
thermostat,' relay module or cable communicating from stat to modem
May 06, 2014 | Dometic Heating & Cooling
My car Keeps shutting off when I turn on and off the AC/Fan
You would need to find out if it is a problem with the compressor or the blower motor. You could pull the compressor relay or unplug the compressor to find out.
Jul 27, 2013 | Hyundai Motor 1999 Tiburon
The side door is getting hot
Pull the unit out away from the wall. Remove the bottom cardboard or metal cover that covers the compressor area. Assure that the compressor fan is working usually when the fan is not working the sides of the unit will start to heat. If the compressor fan is not working shut the unit off until the compressor cools. I have used a box fan while leaving the cover off on a unit to keep the compressor cooling while I had to wait for the new compressor fan motor to come in. DO NOT RUN THE REFRIGERATOR IF THE FAN IS NOT WORKING UNLESS YOU HAVE SOMETHING TO KEEP THE COMPRESSOR COOL like a fan constantly blowing on the compressor. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
Sep 08, 2011 | Refrigerators
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
My unit shuts down after 45minutes an blows hot air
Sounds like a bad Condenser fan motor. The fan keeps the compressor cool. If it is broke the compressor will over heat eventually and shut off.
Oct 21, 2009 | Heating & Cooling
Outdoor A/C unit fan
If the fan and compressor are shutting off. its possible its cycling on a low pressure switch. probably low on freon.
or you have a low ambient kit to keep pressures up during low outdoor temps while ac is running just the fan will shut off, however thats not a typical thing to have a residential system
Sep 20, 2009 | Heating & Cooling
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Fedders A&B Chassis A1A07W2B Air Conditioner Logo
19 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
