Question about Mitsubishi WD62527 62 in. LCD HDTV
My Mitsubishi wd 62527 makes a grinding noise
That's it
    Top Expert:
  • Mitsubishi Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Sounds like the fault with its back-light inverter board. Contact any service technician.
Posted on May 07, 2014
Mitsubishi wd 62527
Possibly the color wheel which is not available, you have to go with the optical engine which is part#: 938P015020
This would make repairs UNECONOMICAL
OR any one of 5 fans:
Chassis fan & Lamp fan: 299P288010 $20.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS fan: 299P296010
Ballast fan: 299P287010 $25.00
http://www.shopjimmy.com/catalogsearch/result/?q=+299P287010
L/V fan: 299P295010 $27.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P295010++
May 06, 2014 | Televison & Video
Mitsubishi wd 62527 makes a grinding noise but the picture is ok
possibly 1 of the fans has noisy bearings.
chassis & lamp fans pt# 299P288010 $19.95@ http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS Fan pt# 299P296010 $65.83 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=299P296010&search_submit.x=29&search_submit.y=12
Ballast Fan pt# 299P287010 $27.95 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?storeid=*20aab4584c1a864062e01c3c70e68e24afb3&search_field=299P287010&search_submit.x=29&search_submit.y=5
L/V Fan pt# 299P295010 $55.13 http://www.tvserviceparts.com/cgi-tvserviceparts/sb/productsearch.cgi?search_field=%20299P295010
otherwise color wheel bearings going out and is not available, must get complete light engine
pt# for WD-62527 938P015020 $629.66
http://www.tvserviceparts.com/938P015020.html
Economically the fans are not too bad, but the light engine would not be cost effective.To determine which fan may be causing the noise, you just have to listen closely to tell which one. or replace all 5 fans for a total of $188.81. you might want to replace the unit with a New LED TV. Replace TV is my recommendation. This unit is too old & antiquated to put this kind of money into it!!
My tv a mitsubishi d 62527 the green light kees blinking
Called the blinking green light of death---set should if power lost when put back blink for 70 seconds or so---digital unit booting up.
About the only simple cause is in the main power supply are four 1000 uf caps that puff up and fail--provide boot up voltage.
follower power cord to supply and look for bad caps (they will be easy to spot) and see attached photos of what to look for.
Nov 06, 2012 | Mitsubishi WD-62527 Compatible TV Lamp
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Jul 15, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD62527 62 in. LCD HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
