Question about Jacuzzi Pool & Spa
Do you have a solution for the bearing of my rotating jet on a j345 spa ho broke once a year ?
    Problem Solver:
  • 29 Answers
I replaced the jet on my spa, check with you spa dealer for the correct part number.
Posted on May 24, 2014
2 Suggested Answers
SOURCE: I have the ball bearings showing up in my lounger
You can use the spa as usual. The missing ball bearings are only going to affect the jet that they fell out of, and since the bearing is already falling appart it is not going to hurt a thing. Most jets have non replacable bearings, so you will need a whole new jet anyways.
Posted on Mar 06, 2010
How do I clear an air in a j345 jacuzzi
make sure all the unions to the pumps are tight
Sep 15, 2014 | Pool & Spa
Morgan spa diagrams
The water jets in most spas are adjustable so you can turn the water flow down to just a trickle if you want to.
You don't take current spa jets out of the spa. They are held in place by a couple of tabs. Through the years the chlorine/bromine will deteriorate those tabs and the spa jets will start "popping" out when the jets get turned on.
If you pull the jet insert out the socket they are in, you will ruin the jet insert and it will need to be replaced.
Rod
US Parts Center Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 13, 2014 | Pool & Spa
Hi, I've had my spa ALMOST 5 years and I have
The balls are out of the spinning jets, expensive if you need 20 or 20, can replace with fixed ones at low cost
Jul 18, 2013 | Pool & Spa
Inner spa jet orifice has broken off
this company blows fiberglass liner into the existing pipe.
Flow-Liner® Systems LTD.
Specializing in Trenchless
Non-Invasive Products & Systems
"We Keep the World Flowing™"In the US 1-800-348-0020
International: 1-740-453-9387
Sep 22, 2017 | Pool & Spa
Hi. We have a 10 year original owner Hydropool spa which we have replaced alot of stuff in the past 6 months. It now reads HO or something close to that and won't get past the 50's - 70's for temperature....
the code might be FLO and could be the circulation pump has debris in the impeller so when idling it should have pretty good flow coming out of the jet the heater uses. other common failures with heat are the pressure switch seen pictured. let me know and pictures help me help u
hayward-fdxlwps1930-water-pressure-switch-replacement-for-hayward-universal-h-series-low-nox-pool-heater_16953382-5wza5llwn2qwnlqvdjcvdeqf-3-0_0.jpeg
Aug 01, 2017 | Qca Spas Paradise Hot Tub
Some of the jets are not working how do we fix it
Assuming this spa is equipped with the single pump system and the rest of the jets are functioning as expected, you need to check to see if the jets that are not working are closed or shut off. Most jets can be opened and closed by gripping the outer ring of the jet face and rotating in either direction. If the jet has sand or gritty debris inside, the jet assembly may not turn easily and will likely need to be taken apart and cleaned. Most jets can be rotated counter-clockwise beyond a detent and pop out. Others require unscrewing completely or by releasing an internal latch to remove. If you need further assistance with this, feel free to contact us.
The jet could also be stopped up with debris, preventing the jet from working.
Taking it apart and cleaning it will likely resolve your non-operational issues.
Nov 26, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Kenmore 16532 dishwasher,three years old. It has slowly gotten very noisy. I have stripped down everything I can access from the tub, including the chopper. I can't find any problem. It is quiet while the...
It could be 2 things:
a) water obstruction in the spray jet ports causing uneven rotation of the spray arm.
This uneven rotation will eventually wear out the motor bearings.
Fix: clear out any clogged spray jet ports.
b) the motor bearing are already shot, and they're growling and howling in pain as the motor grinds them to death.
Fix: replace motor - new bearings will come with the new motor.
Alternate Fix: replace dishwasher. Often new motors are so expensive, replacing the whole unit is the bast option, especially with Sears/Kenmore (where parts are expensive)
Try: www.SearsPartsDirect.com.
I tried the sears parts web site for you, but you model number came back to a Bissel carpet cleaner.
Oct 15, 2010 | Kenmore 24 in. 16532 - Multiple Color...
I have a Paradise II, had it installed on 10/06 around March of this year one of the motors for the jets quit. We shut the spa down every summer so we did not have someone come out and look at it. Once we...
If this is under warranty call the manufacturer. If it was purchased at a big chain store like cost-co call them. It is very common for hot tubs that are shut down most of the year to have these problems. The motor shaft seals need to stay wet, but when shut down they are dry. When they go dry they shrink, causing leaks, which will in turn let water leak into the motor housing, which will in turn seize the motor bearings. It is much better once you have it up and running to run it year round, and when not in use, turn down the temperature as well as switching the controls over to "economy" Every spa made in the last 10 years has this setting. It will cost $.25 /day to run like this (about) which is way cheaper than service labor and parts. If you have a good spa tech. he should be able to replace the bearings for $35 each plus one hour labor per pump. If you have a bad spa tech. just pay to replace the pumps or do it yourself.
Oct 08, 2010 | Qca Spas Paradise Hot Tub
I have the ball bearings showing up in my lounger in my spa and now realize that it is probably from a spinner jet after reading several postings. I just filled the tub and put in all new chemicals. Does...
Well.. Ummm... Yes. really to be safe & responsible & to prevent any more damage. Just having it hot & using for a little bit, may be OK, but no water jets etc. No Water Pumping jets etc.
Feb 06, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
66 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
