Question about Refrigerators
Where I would I find an icemaker for an old GE refridgerator model # TBF16SGB?
  • 957 Answers
GO TO APPLIANCEPROSPARTS.COM
Posted on May 07, 2014
CMV9
  • 594 Answers
SOURCE: Whirlpool side by side refridgerator
make sure your ice maker is turned on and if it is a new install than it will take about 24 hours for the first bin of ice witch you will need o throw away because it is like the first snow the first ice that comes out will have the dirt and things that are in the line.filter and ice maker.
Posted on Aug 22, 2008
Bat1956
  • 585 Answers
SOURCE: GE Side by Side Stainless steel Ice Maker water will not shut off
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
Posted on May 19, 2009
  • 101 Answers
SOURCE: GE Arctica (Top Freezer) Refridgerator
bad control board
Posted on Sep 09, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE refridgerator model GSS221FRFBB about
Hello, welcome to FixYa.
With the info you posted, I understand your GE fridge icemaker will make ice, but not extract it/complete the harvest, correct?
It may actually be nothing serious, but it will require some investigation by way of pulling the icemaker out of the freezer.
Once you've got the icemaker out, inspect the icemaker mold and clean it by placing some "white vinegar" (where the arrow points in the image below) in the mold and leaving it for a hour or so and then cleaning the mold out.
Often water deposit and sediment build up in the mold which in turn prevents the ice from extracting as it actually "sticks" to the mold. Cleaning the mold often remedies the problem if this is the cause.
It is also possible the mold heater isn't coming on to allow the bailer arm to push the ice out of the mold, ( but that will also normally manifest in the bailer arm "clicking" as it tries to harvest the cubes) but I'd suggest checking and cleaning out the mold first.
Let me know how you manage and I'll try to assist you going forward in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Jun 25, 2011
richroth
  • 9472 Answers
SOURCE: Refridgerator repair: I have a GE refridgerator and my Icemaker is freezing up at the end where the water comes out into the ice tray what could be causing it to freeze up I don't have it turned
What is the model number and I will post the fix for you?
Posted on Oct 23, 2012
How to remove samsung imc701 icemaker from refridgerator
Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
GE refridgerator 3 years old just stopped cooling.
No model # for reference. The sky's the limit without a model #. Could be
Compressor, Motherboard, leak, cold control, defrost control, start devise, wiring issues.
Ric
Mar 10, 2010 | GE GSL25JFPBS Side by Side Refrigerator
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling, freezer is working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge PDS22MBSWW - relay clicks on and off
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
Sep 21, 2009 | GE Profile PDS22MBSWW
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
May 18, 2009 | GE Refrigerators
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
