Question about Office Depot Ativa CX12W Shredder
"How do you empty the shredded paper"
Is there a release button somewhere? Thank you.
  • Rita
    Rita May 08, 2014
    Hi, I am unable to shred new items because the shredder is full. How do you empty it? I don't want to force it. Can you please help or is there an 800 number I can call? I have the CX12W model. Thank you very much.
    Problem Solver:
  • 5 Answers
Hi Rita, usually the collection try is not any sort of tricky step, so you may have to do as you have mentioned, and force it alittle. Use only your muscle power and hands. If you introduce other tools, bad things may happen.
Good Luck
Posted on May 08, 2014
    Problem Solver:
  • 6 Answers
Ativa -Product Support Team
If you are experiencing hardware-related issues and the information available in Frequently Asked Questions or User Manuals did not address your question, please call the Product Support Team with your questions.
Phone number: 1877-777-HELP (4357)
Hours of operation:
Monday through Friday
8AM to 8PM Eastern Standard Time
Closed on New Year's Day, Memorial Day, 4th of July, Labor Day, Thanksgiving, and Christmas Day.
By Mail
6600 North Military Trail
Boca Raton, FL 33496
Posted on May 09, 2014
We have a fellowes shredder. It got full and jammed. After cleaning and emptying it will not turn on. Is there a reset button? Thanks. Betn
We've found that when the container is overfilled with shredded paper, it will begin pulling shredded paper back into the cutters and jamming the machine. Sometimes reversing the machine will spit the paper back up, but if it is thoroughly jammed, only way to unjam it is to UNPLUG it first, then manually remove the paper from the cutters. Then, be sure to dump the container BEFORE it is filled with paper.
Jan 12, 2017 | Fellowes Office Equipment & Supplies
How to restore shredding capacity?
Access the mechanism and spend some time picking out all the bits of paper jammed in it.
Aug 22, 2016 | Office Equipment & Supplies
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Do you have info on paper shredders that just stop
shredders have a small tag next to the cutter wheels that move when you insert paper to shred. This tag is easily jammed or damaged during operation. It is normally about the middle and will be positioned between two blades. If this is not moving when paper is inserted it will not switch the machine on. It is the same switch that wwhen jammed by paper will not switch off the machine after paper has been shredded.
Nov 08, 2014 | Office Equipment & Supplies
Staples titanium shredder
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Jan 08, 2014 | Office Equipment & Supplies
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
Office Depot Ativa CX12W  Shredder Logo
98 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
