Question about PetSafe Wireless Fence System PIF-300
Petsafe 300-1051 repair
Is there a way to check the 300-1051 transmitter. Looop light comes on, no break in wire.
My running lights are not working but my break lights in my headlights and my blinkers do
Here is what another did to fix the problem: " just checked all my fuses, all were good. I checked the bulbs, all were good. I checked to see if I had power at the plug into the lamp, no power for the running lights. Hopped under the rear bumper and found where someone had done a crummy
repair on the brown wire coming in on the main harness and it split off to two brown wires to each light and fixed the repair and lights work now. "
May 10, 2015 | Cars & Trucks
Why does trac off light keep coming on?
Probably a frayed ground wire, shared with other idiot lights (both check engine lights, brake system fault light, low oil level/pressure light) and the fuel pump. It is a multi-stranded wire that passes over the top of the transmission on the way back to the fuel pump mounted on the rear, center, of the fuel tank.. As the strands break due to flexing, various idiot lights intermittantly come on, until enough strands break to make them stay on, then finally stopping the fuel pump from pumping. Repair the frayed ground wire (most likely as it passes over the transmission), and everything goes back to normal.
Jun 30, 2014 | 2000 Chevrolet Cavalier
Cat flap
No... unless the door is removed entirely or you customize.
Apr 25, 2013 | Radio Fence PetSafe Freedom Pet Doors
2003 Ford Fiesta, Parking lights come on when break is applied
Check for dual filament lamps installed backwards and wrong type of lamps installed
Feb 26, 2013 | 2003 Ford Freestyle
Diagram for wiring for break lights on rav4 1996
The AutoZone website may have a wiring diagram in the sites self help repair section.
If you have a voltmeter check for voltage and ground continuity at the bulbs. Check for voltage before and after the brake switch (operate the switch). If you don't have a voltmeter connect something up with a 12V bulb.
If you have voltage after the switch (when operated) but none at the bulb might check the brake/tail light sensor. This is the actual sensor box located in the trunk, drivers side. The sensor can fail resulting no brake lights.
There have been various posts at this forum on the sensor, suggest you do a site search to find these and review them.
But first start checking for voltage.
Apr 01, 2012 | 1996 Toyota RAV4
My ford f250 will not come out of park. What is
check that you have brake lights. fords are well known for wire to brake light switch breaking, repair wiring if broke. replace brake light switch if not working brake lights and wire ok and fuses ok. recommend checking with test light before replacing. just ground test light clip, touch 1 side of switch and should light up tester, other wire should light up only when applying brakes. if this doesnt solve issue, seek professional help via electrical repair shop or ect...
Apr 29, 2010 | 2002 Ford F250 Super Duty SuperCab
How do I take an iTrip apart?
Cut around the seam with a sharp xacto knife. It will open.
the crystal had come loose. I glued and sildered it back on. I'm back in usiness.
Jan 05, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Will not transmitt after triple 520 final kit install,will receive fine
rather than use a small linier you decided to break your radio instead . It still sounds like a cold solder point to me .
May 26, 2009 | Galaxy Radios DX-66V Base CB Radio
PetSafe Wireless Fence System PIF-300 Logo
187 people viewed this question
Top PetSafe Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a PetSafe Pets - Other Expert? Answer questions, earn points and help others
