Question about Drills
Milwaukee 4096 dymodrill
I'm having problems replacing the cord. Any help?
    New Friend:
  • 14 Answers
Http://documents.milwaukeetool.com/58-01-0930.pdf
Posted on Dec 10, 2014
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
I need to replace my power cord on a Milwaukee 4096 dymodrill
Check to see if any of these work for your drill. There are some cords in the search results that seem universal for Milwaukee drills.
Milwaukee 4096 dymodrill power cord
May 06, 2014 | Saws
My dog chewed up cord. How do I repalce Milwaukee Model 6507 Sawzall
this should be a twist lock cord and all you need to do it twist the connector at the handle area and pull the cord off and buy a replacement, make sure whether it it grounded (3 wire) or double insulated (2 wire), you can go to Milwaukeetools.com and with your serial number look at a schematic for this tool and they also have a dealer locator to ensure that you get the proper one. Let me know if you need more assistance.
Sep 19, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
What is Fixya
FIXYA is a technical support site that if you have a problem someone will try and help you or direct you in the right direction to get your problem solved.
Jun 28, 2011 | Milwaukee Tool Milwaukee 10 Amp...
Replacement cord
you should be able to look in the phone book yellow pages under tools,electric repair to find one or you can buy them direct. Let me know the brand and model number with a zip code location and I will try and find an original one locally for you.
Jan 23, 2010 | Milwaukee Tool Milwaukee Angle Grinder -...
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
I need to change the cord on my 9392 Milwaukee Drill. The trigger does not have any screws and, I cannot not see how to change the cord out. The ground wire is attached to a screw connector.
On the trigger switch, if you look really closely you will see that there are clips inside where the wires go in. If you use a jewelers flat screwdriver or other narrow flat instrument, you can push the clip back enough to release the wire.
If the replacement cord doesn't have clips on the ends of the wires, make sure that you tin (apply solder) to the ends of the new wires before inserting them into the trigger. This is needed to keep the individual strands from being pushed everywhere and causing a short, and stiffens the end, making it easier to insert.
If you need further assistance, let me know.
If this was helpful for you, please rate the solution.
Apr 20, 2009 | Milwaukee Tool Drills
Milwaukee 28v battery problems
Take a look for warranty, and contact them ... If your warranty is out of date, than you must get new one. The best place is amazon for sure, Milwaukee 48 11 2830 M28 Lithium Ion Battery Pack. Hope this was helpful, cheers
Apr 14, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
New switch
OK make a drawing of the back of the switch, you should see 5 openings 2 already with wires in them. From back upper left is black supplied with switch upper right is yellow from the field middle is also a black supplied with switch lower left is black from the power cord and lower right is white from the power cord. Let me know is any more problems
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Barrel won't turn
by barrel I take it you are talking about spindle? This might be the version that has an internal clutch mechanism that would require you taking it in for service. If not there is a shear pin in the spindle that might need replaced. Hope this helps
Dec 03, 2008 | Milwaukee 4096 Diamond Coring Motor...
Drills Logo
140 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
