Question about Arcam AVR-200 Receiver
Fuse size arcam a65 - Arcam AVR-200 Receiver
2 Suggested Answers
  • 6771 Answers
SOURCE: Arcam A65 amplifier keep on go to standymode why?
Depending on the volume level and how many speakers you are driving factor into how the amp will react. Check the speaker wires for shorts, if okay! then we must look at the audio output stage, if the semiconductors are getting to hot, the satety circuits will cause a shutdown, if you run a pair of speakers the amp will run cooler, if you recently added more speakers that would explain the shutdown, if not! there is a problem in the audio output transistors and ic's that will need to be dealt with.
Posted on Apr 14, 2012
Arcam repair
Maybe a firmware (that's the running program) problem I'd contact Arcam, if your Solo has a USB input they should be able to send you a firmware update which you can download to a USB stick and then upload to the Solo (instructions will be in the manual). If not your local Arcam dealer should be able to do it for you Arcam warranties are 3 to 5 years. Don't now if they'll edit this but also try AV Forums online. good luck
Aug 19, 2014 | Arcam Audio Players & Recorders
Apr 14, 2012 | Arcam Audio Players & Recorders
We just purchased an LG, LED, LCD, TV and just realised that our existing Arcam AVR 100 does not have an optical out. Does this mean we need a new amp or are there alternative solutions? Many thanks.
Actually, it doesn't have ANY digital outputs. Just what do you require one for? Name specific models and functions when replying.
Do you think the TV NEEDS optical audio from the receiver? Maybe the TV could survive on just analog audio from the video source, while the GOOD audio goes to the ARCAM since the ARCAM is going to do the hard work of managing and driving the REAL speakers.
http://www.arcam.co.uk/_ugc/file/avr100e_manual.pdf
Feb 06, 2011 | Arcam AVR-100 Receiver
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Jan 17, 2011 | Arcam AVR-200
My cd player stopped working the power light is not showing i have changed the lead to make sure it was not the fuse
Check for bulging / leaky capacitors on the main PCB, they are a common problem on Arcam CD Players.
There should be a few 25v 1000uf caps scattered around, check those first.
Hope this helps.
Dec 04, 2010 | Arcam Alpha 7SE
How to hook up a computer sub to a hometheater amp
http://www.arcam.co.uk/_ugc/file/avr280e_manual.pdf
If you have the whole Z5500 package you could run the Arcam's optical- or coaxial digital audio output to the corresponding input on the Logitech.
But I'd be careful about letting BOTH the Arcam and the Logictech perform Digital Sound Processing on the sound. DSP's aren't meant to be stacked. My money says the Arcam is better in the DSP department than the Logitech.
If you have just the sub, run the Sub PRE out from the Arcam to the Sub/Center input (adapt it to 3.5 mm) on the Control Center and set the switch to "6 ch direct".
Mar 06, 2010 | Jensen JW250 Main / Stereo Speaker
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Arcam avr300 intermittent problems
I had this same problem with my Arcam AVR300. I ended up shipping mine to an Arcam repair center and they repaired it and shipped it back for under $200. The problems were cracked connection on the start relay and they replaced power supply diodes. Very well worth it and now I can enjoy it again!
Jun 30, 2008 | Arcam AVR-200 Receiver
Arcam AVR-200 Receiver Logo
Top Arcam Audio Players & Recorders Experts
 Grubhead
Grubhead
Sock Puppet
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
