Question about Compaq Computers & Internet
Install dvd drive on compaq presario v5000
Getting a new dvd drive for my laptop
    Genius:
  • 1,552 Answers
If you need to ask "how", you should take it to a qualified professional technician. Or, $30 is the price for an external CD/DVD-writer that connects via USB.
Or, read: http://h10025.www1.hp.com/ewfrf/wc/product?product=499847&lc=en&cc=us&dlc=en
for "how-to" information on your notebook computer.
Posted on Dec 28, 2014
4 Suggested Answers
jepito
  • 216 Answers
SOURCE: nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
bronk50
  • 27725 Answers
SOURCE: laptop compaq presario 2100. i
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
Posted on Dec 05, 2010
bronk50
  • 27725 Answers
SOURCE: compaq laptop presario v5000 cd rom not working
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 24, 2011
I installed a new internal hard drive in my Inspiron 1750 laptop. I am getting a No boot sector on internal hard drive error. How do I get it to boot up and get recognized?
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
Feb 03, 2013 | Dell Inspiron 1750 Laptop
I need to know how to remove a DVD drive for a HP lap top.
If your HP Pavilion DV6000 series laptop computer has a bad DVD drive, use the following steps to replace the drive
Purchase a new DVD drive to replace the old HP drive. You can use any slim DVD drive with a 50-pin ATAPI IDE Interface Connector. You will probably want a DVD burner since the original drive was capable of burning DVDs. The drive I used to replace the HP drive is a LG Black IDE Super-multi Slim Notebook DVD Rewriter - OEM version.
Unplug the power cord from your HP laptop. Remove the laptop battery from the back of the computer. This will eliminate the chance of power damage to your computer
Ground yourself by touching a metal object or touch your screwdriver on the ground while touching part of the metal. Unscrew the DVD drive screw circled in the Step 2 photo. Using a small Phillips head screwdriver turn the screw counter-clockwise until it is completely loosened. You may need to flip the computer over to get the screw to fall out. Put the screw in a safe location for later.
Put a small pointed tip object (a paper clip will also work) into the drive release hole on the face of the DVD drive. Use the hole to pull the drive out from the laptop body.
Remove the mounting bracket from the old DVD drive. There are two small Phillips head screws that need to be removed by turning them counterclockwise. Match the bracket up with the holes on the side opposite of the connection port. Using the two screws you just removed, secure the mounting bracket to the new DVD drive by tightening them in the clockwise direction.
Remove the original HP DVD drive face plate from the old drive. It can be removed by working it back and forth to loosen the faceplate. Once it is loose you should be able to pull the faceplate off.
Do the same for the new drive. Once the DVD faceplate is off, match the tabs of the original HP faceplate up and press in until it clicks into place
The new drive is now ready to install into the HP DV6000 series laptop. There is no need to hook up IDE cables and power cables. The new drive can simply be slid into the HP laptop.
Find the screw from Step 3. Make sure the DVD drive is pressed in all the way. Install the small Phillips head screw in the back of the laptop and tighten by turning clockwise.
Jun 19, 2010 | HP Pavilion dv6000z Notebook
I cut the cable to my dvd drive in laptop ,how do
You will have to get a new one.
I did accendently did this when I was trying to fix the drive in my Dell Inspiron 2200.
What happened on mine:
1. Over time, my laptop's dvd drive was getting harder and harder to open.
2.One day it didn't open at all but the paperclip thingy didn't work, so I had to use my pen knife but that snapped the cable.
I had to get a new one from ebay.
Jan 31, 2010 | Computers & Internet
My DVD-CD drive doesn't appear when I try to use it. When I stick a CD or DVD in the drive it doesn't respond. It's as if it just disappeared. I've tried system recovery and get results but the drive still...
Under your laptop there is a small screw holding the DVD drive in place remove the screw and take the DVD out of the laptop turn on the laptop, then turn it off again, put the DVD drive back in and secure with the screw
then when you trun the laptop back on it should say windows has found new hardware and then it will reinstall the drivers
Nov 30, 2009 | Compaq Presario Notebook
My acer 5315 laptop dvd does not work,when i put a dvd says unable to detect a dvd device on your computer.
Does it read CD's..? Does it only fail on DVD's?
Try installing new firmware, try physically reseating the DVD drive. Try unistalling and reinstalling the device through Device Manager.
If everything fails still, then you have a bad DVD drive and will have to get a new one.
Troubleshooting helps......
Sep 08, 2009 | Acer Aspire 5315-2153 Notebook
Dell vostro 1510 dvd drive problem
update the firmware and or update your dvd drivers
Jul 21, 2009 | Dell DVD-rom DVD Drive
Brand new acer,spindle is too large on multi drive for cds or dvds
There are three little spring loaded things that you have to push together to get the DVD or CD to fit, I had the same problem
Sep 15, 2008 | Acer Aspire 3680 Laptop
Cd dvd drive
Yes its easy to repair / replace the laptop drive. I'm in the UK and charge £30 for a replacement CDRW/DVD and £45 for a DVDRW A new laptop would cost about £300 depending on the make and model. Keep green and get the item repaired.
I hope this is useful please rate the solution as we depend on your feedback.
Mar 29, 2008 | Computers & Internet
Cd/dvd rom
I am presuming that you have the correct driver for the DVD, and nothing else has changed (no new DVD software that might cause this problem by addressing the drive improperly). Nero and Power DVD can both cause problems if your DVD is newer than the software version.
Now, all that out of the way, here is the diagnosis. DVDs are much higher density than regular CDRoms. DVDs average 4.5 gb, whereas a CD is caped at 0.7gb (700mb). Thus, DVD drives have very low tolerance for ANY kind of error. Therefore, DVD combo drives are not likely to last as long as the rest of the laptop's hardware. Shock at relatively minor levels can damage a DVD drive. Often, they will still open a regualr CD, but fail to read a DVD directory. Your error code, if it is posted at startup, indicates the drive is malfunctioning. You can test it easily. Usually there is only one screw that holds it in (underneath the laptop, about 4 inches from DVD tray cover, towards the center). Turn off laptop, flip it over on a towel, and remove that screw. Tuurn the laptop over again, then insert a straigtened paper clip into the small hole in the DVD tray face. Be careful to push lightly and STRAIGHT in with this paper clip and the tray will pop open. Pull gently, and the whole DVD body will slide out. With a new or used replacement DVD or CD, reattach any hardware on your old DVD to the new one, then slide it back into the laptop 9no need to install screw just yet) Start laptop. If error is gone and DVD plays OK, insert the screw again and make your old tray cover fit the new drive (always can be done if you look closely to find the tabs and remove it gently). Sometimes some plastic will need to be trimmed with an eExacto knife to get a good fit.
Feb 16, 2008 | Toshiba Satellite A60 Notebook
DVD Drive Sony Vaio VGN-SZ330P/B
moz-screenshot-1.jpgon the back right on the same space there is 2 or 3 screws remove them and pull the dvd drive like if you wants to pull the disk get new one and reinstall it you can get that on ebaymoz-screenshot.jpg
Jan 01, 2008 | Sony VAIO VGN-SZ330P/B Notebook
Computers & Internet Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
