Will not agitate or spin
Kenmore front loader model #4174404240C
  • 711 Answers
Sound as if the timer is shot. Call your local appliance dealer, often they will sell the parts and give you advice on how to install them. If not that then go to kenmorewashers.com for a complete parts listing and diagrams for your unit.
Posted on May 06, 2014
  • 249 Answers
SOURCE: Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Posted on Dec 11, 2007
  • 2334 Answers
SOURCE: Maytag Neptune front loader, model
The LR can means that the motor has failed or the spinner shaft is seized to the bearing.
Check the wiring harness to the motor it may be loose.
See if you can turn the tub by hand.
If the tub is free and the wiring harness is good preform the motor test.
You will find the test paper in the console.
Posted on Jul 11, 2008
  • 115 Answers
SOURCE: Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Posted on Dec 31, 2008
SOURCE: Kenmore Front loader Washer Problems
u need to remove the shipping bolts, found in the back of the washer, 4 long bolts used to hold the drum in place while transporting. we had same prob
Posted on Feb 04, 2009
SOURCE: Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Posted on Jun 28, 2009
Kenmore front loader stopped washing, or spinning
Is it induction or electronic motor,,,,if its electronic it may be carbon brushes,,,if its induction it may be capacitor
Jun 13, 2013 | Kenmore Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
likely the lid switch is bad - if not the ECU/timer is.
May 28, 2009 | Kenmore 43042 Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
