Question about Blaupunkt Alicante CD32 CD Player
HOW TE REMOVE HOLE RADIO GOT A NEW RADIO FOR MY SUB PINONEER DUAL MASS MAGNET AND A ROCKFORD AMP WITH WHAT TOOL CAN I REMOVE THE RADIO BLAUPUNKT GMDAT CDP B
I DRIVE A chevrolet lacetti 1.4 16v from 12-12-2005 and is standaard with a blaupunktGMDAT CDP B device, number 6 s written by hand on the barcode. i can'tt remove the hole radio i can remove the front but not the box. i need to get to the cabels to instaL a new radio for my subwoofer and rockford amp can you send me the tools to remove the radio. my adres is teijeblauwsingel 17 opeinde 9218RT Holland/Frysland my name is richard van houten. i would like to say blaukpunt is great. the sound from my standard set is olmost enouch. i listen to Hardcore/Gabber i am a dj so i listen a lot. and it just needs an additional bass that is way i want to instal subwoofer. i dont hae a lot of money else i would buy straigt from you. i dont have a phone so if you would like to write me on my e amil richardvanhouten@hotmail.nl thank's
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
Posted on Feb 28, 2009
  • 17 Answers
SOURCE: I need a radio/cd, that would work with my steering wheel control
im sorry but i must be blunt the people who installed your deck were lazy instead look up factory wheel control module on google there is a system that (as long as the deck has any type of remote) allows you to hook this up run a small wire with a out put laser to the front of your deck acting as a remote control if this infact is not the case use crutchfield.com enter in your car information look threw the decks when you find one you like look in eccesorys if its not an option it wont be there :) honestly the jvd avx 820 is amazing for the price check it out it will work with your controls
Posted on Sep 26, 2009
Testimonial: "Many thanks. I will show your answer to the garage. Graz"
dj_relly999
  • 4070 Answers
SOURCE: hi i got blaupunkt cd playrer in my car i don`t no
hi, sometimes it needs a special key to pull the head unit out, its a metal that you insert in both side of the head unit. hope this helps
Posted on Feb 13, 2010
  • 4844 Answers
SOURCE: Hi I need a Radio code for a Blaupunkt Travel
Try code 8427
Posted on Mar 03, 2010
Testimonial: "Thank You for your help worked first time , nice to see the Radio burst in to life , thanks again ."
  • 4844 Answers
SOURCE: How do I remove a blaupunkt alicante radio so I
It should be a standard DIN fitting so the instructions are below
Here is a video showing how to remove a standard radio fromthe dashboard. A pair of extractorsare required (available from Ebay etc ) but these can be made from 2 pieces ofbent, wire coat-hanger or 4 smalldrills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4darts. An assistant isuseful to pull the radio out whilst you are releasing the 4 securing clips http://www.youtube.com/watch?v=urC-4NbXvDQ note: on some radios, these 4 holes are protected by 4 small screws. These can be unscrewedusing the appropriate of Allen key. ====================================================
Posted on Jan 18, 2011
Testimonial: "I havnt noticed 4 holes in this head set unlike my old one. This one seems to have two slots on each side which looks like a flat key is needed. Thank"
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Problems with car system help! I have a little older model rockford bd1000 and 2 TXXAPX12RD audiopipe subs hooked up in parallel/parallel to give it 1 ohm, had it hooked up this way for a good solid 3...
Hello srolson,
When electronic components are brand new their tolerances will allow more variation. Once you get down to a 1 ohm load, the actual impedance may vary somewhat below what the amp is capable of handling. Maxxing anything out accelerates how quickly it degrades. When new the amp can deal with putting maximum power into a minimum load, but as the components heat up and wear with age, the tolerances change.
Hope this helps.
Sep 15, 2009 | Rockford Fosgate bd1000.1 Car Audio...
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
5 stage band pass sub box, 1 sub stolen, box built to spec subs
I would try walling it up unless you are going to buy 2 brand new subs. the problem is the older power subs had such small magnets so they needed alot less air space inside the box. Unless you can find the EXACT subs this box was made for I would recommend chopping it and doing a single sub. if you try a replacement sub go with the 12" P1 series they are a close match for the power 12's of the past.
Mar 06, 2009 | Rockford Fosgate Car Audio & Video
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Hi graz,
Jan 17, 2009 | Blaupunkt Alicante CD32 CD Player
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Blaupunkt Alicante CD32 CD Player Logo
42 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
