Question about CIBA Vision Optelec ClearView 19 Inch LCD Color Auto Focus CCTV LCD TV
Optelec ClearView 17 broken lamp/bulb. Where can I get replacement?
    Top Expert:
  • CIBA Vision Master
  • 74,136 Answers
Posted on May 07, 2014
My Marantz VP-15S1 bulb burned out (with 775 hrs remaining). The bulb was replaced with an LU-12VPS3 replacement bulb/housing unit. It worked fine for about 2 hours and quit working. When I pulled the...
the lamp is a cheap one, you should purchase a original one
we supply the Original lamps for projector since 2002
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Nov 20, 2013 | Marantz VP15S1 Lamp
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
Jan 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Clear view cctv won't turn on
There is the big possibility that you have bad power supply board.
Nov 08, 2012 | CIBA Vision Optelec ClearView 19 Inch LCD...
Why would only 1 of my tail lamps running lights work but on the lamp that is not working turn signal and brake lights work
Many of the front and rear lamps are actually two bulbs in one. If you look at the bulb it will have two filaments inside. One for lights and the other is for the turn lights and/or brake lights.
If one of the filaments is broken, you can usually flick the bulb, and see the broken filament shake.
The problem could be a bad connection, or a number of other things, but go ahead and replace the bulb first.
(If you really want to know, you can switch the left and right side bulbs, and see if the problem moves with the bulb.)
Jul 21, 2011 | 2001 Chevrolet Blazer
PT-AX200U Bulb replaced 4 months ago Was on about
carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Apr 09, 2011 | Panasonic PT-AX200U Projector
How to change break lights
Tail Lights
  1. Open the endgate or liftgate.
  2. Remove the screws that retain the tail lamp assembly to the vehicle.
    Tail lamp assembly removal
  3. Rotate the bulb sockets 1/4turn counter-clockwise in order to remove the bulb sockets from the tail lamp assembly.
  4. Remove the bulbs from the sockets.
To install:
  1. Install the bulbs into the sockets.
  2. Install the bulb sockets to the tail lamp assembly by rotating the sockets1/4 turn clockwise.
  3. Install the tail lamp assembly to the vehicle.
  4. Install the screws that retain the tail lamp assembly to the vehicle. Tighten the screws to 17 inch lbs. (1.9 Nm).
Oct 23, 2010 | 2000 Oldsmobile Bravada
Right side backup lamp wont work
try replacing bulb if that don't work it is either a fuse or a short in the wiring.
Sep 13, 2010 | 1992 Chevrolet Astro Extended
How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Skyassoc
Jul 03, 2009 | LG RZ-17LZ40 17 in. LCD Television
Need instruction manual
Try this website here: http://www.optelec.com/us_en/index.php/products/downloads/
There are several manual listed. The website also indicates "If the instruction manual you would like to download is not shown above, or if you would like an Optelec representative to assist you, please email us (info@optelec.com) or call 1-800-826-4200 (Mon-Fri 8am to 8pm ET)."
Sep 07, 2008 | Optics
CIBA Vision Optelec ClearView 19 Inch LCD Color Auto Focus CCTV LCD TV Logo
104 people viewed this question
Top CIBA Vision Televison & Video Experts
Electro Med Services...
Are you a CIBA Vision Televison and Video Expert? Answer questions, earn points and help others
