1.remove the bolts securing the water pump cover to the engine front cover and remove (3 bolts) watch out for the dowel pins
2 remove the remaining bolts securing the engine front cover and remove cover and gasket(8 bolts) watch out for the dowel pins and the o-ring seals around the openings
3 remove the bolts securing the water pump and remove water pump.watch out for o rings
4 rotate the oil pump shaft so the tab on the end of the shaft is vertical
5.oil the new o rings on the housing
6 install new water pump and tighten up
7 position the groove on the water pump shaft vertically so it will align with the tab on the oil pump shaft
8 install the front cover (new gaskets and o rings)
The above came out of my manual.It looks fairly straight forward but watch out for the little o rings they can be a pain. good luck
For
complete water pump replacing procedure, step by step, there are few help
links.I suggest you to refer the help links.
Click
the link below:-----
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
These
will help.
Thanks.
For water pump replacement i suggest you to check the help link
provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
How to route Water Pump Belt for 1992 Oldsmobile ?
How to replace Water Pump on Car ?
How to Remove Water Pump?
Where is Water Pump located ?
This will help. Thanks
provided below.
provided below.
This will help. Thanks.
provided below.
provided below.
provided below.
provided below.
How to route Water Pump Belt ?
provided below.
How to route Water Pump Belt?
