Question about Pool & Spa
I have an inground pool with a Breeze Saline Generating System and an "extreme-E 1081 pool pump motor, model# B63GZAAU-1017, catalog# EB2975T, NIDEC MOTOR CORP. , where can I get an owners manual that shiws me how to turn the filter, vacuum, etc. on and off or program? I just bought the house and have no idea how to work it! Thanks to anyone that can help me!
  • 957 Answers
I AM NOT FOR SURE THEY WOULD HAVE IT BUT I THINK THEY COULD TELL YOU WHERE YOU CAN DOWNLOAD THE INFROMATION. GO TO NATIONALPOOLS.COM
Posted on May 07, 2014
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
SOURCE: Need Owners Manual for Intex Krystal Clear Model 635 Pool Pump
The manuals are indeed free and available online. I just downloaded the manual for my pool.
Don't trust people telling you that you have to buy something ;)
This is the link to the Filter Pump manual page.
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Posted on Jul 12, 2009
  • 4350 Answers
SOURCE: I have an Emerson 1081 Pool Pump Motor , every
Well, something is wrong. Either the pump or the wiring from the switch to the pump. Pull the pump and take it to a motor shop and have them check it out.
Posted on Oct 20, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: Hello , I have a 5yr old pool complete with
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Posted on Nov 16, 2010
Testimonial: "Thank you -- the 2hp motor provides air induction and bubbles. There is no foam to break off. I did blow system out , still the same. Will keep lookin"
joeguest2
  • 2080 Answers
SOURCE: Need owners manual for Baqua Pure Filtration
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.tuffpools.com/pdf/Baqua_Pure_Sand_Filter.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
Thank you very much and good luck.
Posted on Apr 23, 2011
What is gpm flow for this pump
for the 1hp size this pump is capable of generating 76 gpm at 0 feet of head pressure of course it goes down from there as you increase head pressure (lift)
May 28, 2014 | Pentair Pinnacle High Performance 1 HP...
I need a manual
For what?
its just a motor.
do you need wiring assistance?
what is the model, code or serial number of the Emerson motor?
and... 1081 does not help!
That just means it's a 'Pool' motor casing.
Feb 16, 2014 | Emerson Pool & Spa
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
How to replace the capacitor on emerson 1081 pool pump motor
remove the bump on the motor make sure power is off then discharge by shorting a screwdriver from the leads to the case then take a picture of wiring or make a note then match it up at a electrical supply store then replace
Jul 07, 2012 | Emerson Pool & Spa
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Whisperflo Pump 1.5 Hp problem
The pump is probably fine the motor is the problem. If it just hums it might just be the capacitor on top of the motor. Don't know how long it sat there not able to start. Was the motor extremely hot ? If it got too hot may have damaged the motor. Motor is replaceable without replacing the pump head.
Sep 30, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Pool & Spa Logo
63 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
