Question about Cameras
Stealth g9 is not charging - Cameras
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
Aug 21, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
MY CAMERA DOESNT TURN ON THE BATTERY IS FULLY CHARGE
The Canon G9 has a design defect, two screws fall out inside the camera and short out the fuse. If you've never had it fixed for no power before this is most likely what has happened to your camera.
Do a Google search for "canon g9 no power repair" and you will see a full repair service including return shipping of your camera for just $85.
Hope this helps!
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Feb 23, 2011 | Canon PowerShot G9 Digital Camera
My Canon G9 Powershot will not switch on at all. It was working fine then the next time I tried it would not switch on. It was not dropped or was it exposed to water. It about 3-4 years old. The battery...
Hope this helps!
Thomas Drayton
Affordable Digital Camera Repair
Feb 01, 2011 | Canon PowerShot G9 Digital Camera
My cannon g9 camera stopped working. the lens is stuck open and it won't turn on. Any suggestions?
Common no power problem on the G9, you just need to get it serviced. There's a great site that only services the Powershots, they're amazing when it comes to servicing these models. On the G9, they do a fix in the camera so the short never happens again which is great, plus they service up the rest of the camera. They don't charge much and they're amazing if you need help with a Powershot. Try them, their site is: camerasandparts.com Good luck, that's the best place if you need help with a Powershot problem.
Jun 15, 2010 | Canon PowerShot G9 Digital Camera
Will not turn on
This is likely the cause of an internal screw that has come loose, it's very common on the G9. A great place to get help with this G9 problem is: camerasandparts.com since they just specialize in these powershots. They not only have the fix available but they have the correction so this never comes back, that comes with their no power service for the G9's automatically. I hope that helps, that's the place if you need help with a powershot, best of luck
Jun 02, 2010 | Canon PowerShot G9 Digital Camera
Somebody was using my canon powershot g9 and when they gave it back to me the lens was out and it was dead. Ive tried everything from charging the batteries and everything nothing is working. Please help!
Camera likely has a common short that comes up on the G9 camera. You just need to get the camera serviced and you'll be back in business again. The site that specializes in service for the powershots is: camerasandparts.com They're amazing if you need help with one of these, that's all they deal with. The good thing with them is they do the correction so that common short never comes back again on the G9. Good luck, that's the place if you need help with a powershot model, they're excellent when it comes to service for these.
May 20, 2010 | Canon PowerShot G9 Digital Camera
My Cannon G9 digital camera wont power up even though I have a fully charged battery?
This is usually from a loose screw inside the camera, a screw inside the camera can come loose and cause a short which is very common on the G9. If you go to: www.camerasandparts.com all they deal with is service for the Canon Powershots. They're great if you need a hand with one of these and they automatically do the no power correction on the G7's and the G9's they service which is nice. They are about the least expensive out there at $89 and they include the service and the shipping back. The best part, they do excellent work which is a must for me. Hope that helps you some.
Aug 17, 2008 | Canon PowerShot G9 Digital Camera
Cameras Logo
11 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
