Question about Electrolux 23 in. ESI602X Built-in Dishwasher
My Electrolux model es1602x will run but won't realise the tablet to wash them? What can I do? Thank you
  • 957 Answers
I HAD THE SAME PROBLEM WITH A WHIRPOOL WASHER AND I REPLACED THE SOAP DESPENSER AND THAT TOOK CARE OF THE PROBLEM.
Posted on May 07, 2014
Why is water not heating in cycle?
Hello Kevin, thank you for your post!
From my understanding your Electrolux dishwasher is not fully dissolving the detergent tablet. It may not be an issue with the water heating up it could be a possible problem with the water not receiving adequate pressure or not enough water. Does your dispenser have any build up inside of it? Have your spray arms been recently cleaned? I would recommend cleaning the dispenser and spray arms out. I can also provide you with information regarding any heater inside of your dishwasher. In order to do so I need your model number. You can locate your model number on the inside wall of your dishwasher. With this information I would be happy to assist you further. -Matt
Feb 02, 2016 | Electrolux Dishwashers
Set timer
Good Afternoon Faye, this is Z! Thank you for your post!
I see you are interested in how to set timer and delay start on your Electrolux washer. However, may I please have the model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I provide you the correct instructions on how to do so. Thank you!
Mar 28, 2014 | Electrolux EW1000i Front Load Washer
Electrolux 8kg won't run
This is probably normal operation , you can press the start/pause and cancel button at the same time to see if you have a error , if you get E00 this means no error if you get a E21 (example) then look and see what that error is
Feb 20, 2013 | Electrolux Washing Machines
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have an Electrolux washer model EWFLS70JSS. The bleach dispenses during the rinse cycle rather the wash cycle. I thank you in adavance for your help.
This is a siphoning problem. Please clean out the dispenser cup(s) as much as you can and try again. You may need to clean the unit and run vinegar through instead of bleach to unclog any small components.
Jul 23, 2012 | Electrolux EWFLS70JSS Washer
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
I have an Electrolux ESL6115 dishwasher model and although there is water coming out and the spray blades seem to be turning the dishes are always wet after the cycle has finished and there appears to be...
Its possible that if you live in a hard water area that limescale buildup is causing this problem if salt levels got low. The first thing that can be done is to run it with 2 or 3 cups of vinegar added & see if it cures it. If it won't accept opening the door to add this after wash has started then add it in a wide dish to catch water & wash it out during cycle. Adding a dose (half cup) of bicarbonate of soda alongside should work even better. This has worked really well for washing machine about to give up on & do regularly to prevent problem. Hope this helps.
Apr 28, 2011 | Electrolux 23 in. ESL6114 Built-in...
Open Questions:
Electrolux 23 in. ESI602X Built-in Dishwasher Logo
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
