Question about Dell 3100cn Laser Printer
Why does my dell3100 printer keep saying to reinsert majenta cartridge?
I replaced the toner cartridge and it keeps saying to reinsert.
SOURCE: right cartridge incorrect
alraedy tried that one but thnx
Posted on Oct 05, 2007
dan231
  • 236 Answers
SOURCE: how do you replace the toner cartridge on a dell printer 1110?
Here is the manual for this printer.
You should be able to pull down on the front cover and pull out the toner.
Posted on Dec 08, 2008
SOURCE: 3100CN keeps asking to replace black toner tried 2 new catridges!
After installing the toner cartridge the replace toner message will reappear after the calibration sequence until you press the menu button on the front of the printer. After doing that the message goes away and you should be ready to print again.
Posted on Dec 13, 2008
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
onynn
  • 5 Answers
SOURCE: wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Posted on Sep 09, 2009
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
Mar 28, 2016 | Samsung CLX-6200FX Printer
Kyocera 3050 won't stop asking for toner after replacing...little door IS opened. thanks
Thanks for that question but idnt think that what you are saying is true but the solution is here my friend i hope your are technician just look at your toner drive inside your machine whether its matching with that one of your toner cartridge you have if not get a cutter and try to shape well that drive which drives toner inside your machine if the problem persist email me @kagimuj@ymail.com immmediately thanks
Jan 07, 2015 | Kyocera Office Equipment & Supplies
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
The printer will sudden come up with the Toner Empty message and stop printing. This only happens on the black toner cartridge. I have replaced the cartridge twice when then cartridge was clearly not...
There are two ways to continue printing:
Setting the menus to allow continued printing after it reports a toner empty
Mechanically resetting the toner cartridge
there is a way to reset the toner cartridge essentially fooling the printer into thinking it has a brand new cartridge. It has a mechanical linkage which will display a small shiny surface when deemed empty by a SW gas meter. (number of dots printed) To reset this linkage it is necessary to remove 3 phillips screws on the end of the toner cartridge which faces the back of the printer. Don't touch the rubber roller or you will get toner all over yourself and possibly contaminate the roller. If touched use rubbing alcohol on a swab to clean off the oil spot. Then on the bottom of the cartridge there is a small black phillips screw going through a copper contact. remove the screw. Lift the copper contact slichtly and pull the plastic end cap off the toner cartridge. remove and reinsert the black plastic interlock device (slides on a plastic rail) such that the sliver surface is fully retracted. replace the end cap, guiding the copper strap in place. Reinsert the 4 screws. Reinsert the used cartridge and keep on printing! Should save you about 20% on the needless replacement of perfectly good toner cartridges. I expect you could refill the cartridge as well if you wanted. Looks like there is a plug under the color coded handle in the front of the cartridge. Be sure to reset the latch as described also.
I hope your problem gets solved. Regards, Nandini.
Sep 14, 2009 | Konica Minolta magicolor 2300DL Laser...
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
2605dn says "replace supplies" points to black
You might have an issue with the cartridge lockers. Be sure to clean cartridge contacts and HV pins in printer. Doesn't help? Do like this. In the printers menu, under system set up, then print quality, then replace supplies there you can choose override out. Print a status page and check status for the cartridges, if the printer don't prints in override mode you have a brooken cartidge locker. In that case, remove all toner cartridges and check the lockers by moving cartridgedoor in and out, do all works the same way or is any of them different?
Dec 05, 2008 | HP LaserJet 2605dn Printer
Dell 3100CN w/new black toner cart reads "Black toner LOW"
service your printer and change roller taplon tape and fuser aseembley.
Oct 09, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
15 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
