Question about Samsung CLP 315 Laser Printer
Paper tray not resetting "on" light - Samsung CLP 315 Laser Printer
  • Brian Parkhurst May 06, 2014
    dropped paper tray. All movable parts seem to be working. Release mechanism for tray to push paper up to "pick up" roller work manually, but seem not to release when inserted into printer (not sound of their release). If I'm not mistaken, the paper must be "up" so that some internal contact knows that it is okay to release STOP mechanism and allow printer to operate.
  • Brian Parkhurst May 08, 2014
    Turns out problem of paper feed related to small piece of paper lodged behind cartridge drum, which was not notice until blown free by hair dryer. Thanks for support. Will be more thorough investigating next time.
    Habit-Forming:
  • Samsung Expert
  • 150 Answers
SET THE CORRECT PAPPER SIZE IN MACHINE
Posted on May 08, 2014
How to reset paper tray in Richo Aficio 2045e photocopier
Verify the paper blocated under tray or the paper tray actuators.
Jan 04, 2012 | Office Equipment & Supplies
Triangle with exclamation mark is flashing orange. What's the problem with it?
This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Feb 07, 2011 | HP LaserJet 1320 Printer
The copier is jammed - the copy light and load paper light is on and I can not get the copier to reset.
Have you removed the paper tray to see if there is a piece of paper behind the tray ? Paper will frequently go behind the tray and wind up in the size switches and or the tray lift gears.
I would check that first. Let me know.
Aug 11, 2010 | Ricoh Aficio 1515 Black and White Copier
Printer makes noise and doesn't print. The triangle sign is lit up.
The printer displays an orange blinking attention light which will not clear.
1.Insufficient power.
2.There is a paper jam in the printer.
Click here for information about clearing paper jams from the HP Web site at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00230694.
3.The top cover is open.
4.No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick.
Perform the following steps to load tray 2.
a.Pull the tray out of the printer and remove any paper.
b.Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
c.Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
d.Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
e.Slide the tray back in the printer.
5.The tray 2 paper level indicator is stuck.
Click here for instructions on repositioning the tray paper level indicator (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
6.If the printer comes back to a Ready state, print a Self-Test/Configuration page.
a.Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
b.Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7.If the attention light is still on, perform a cold reset.
a.Turn the printer off.
b.Press and hold down the green GO button.
c.Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
d.Release the GO button.
e.The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
This is generic information for HP laserjet printer,
if you still have problem, please leave the printer model and make as comment and we may hel you
Rnj VINODKUMAR
Oct 17, 2009 | Office Equipment & Supplies
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
Oct 02, 2009 | HP LaserJet 1320n Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
An orange light is on next to the triangle with the ! in it. I thought it was out of ink but have just replaced the cartridge and its still doing nothing!
Perform the following in the order provided to troubleshoot and resolve the issue. 1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
Jan 09, 2009 | HP LaserJet 1320 Printer
Yellow light
    1. Pull the tray out of the printer and remove any paper.
    2. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
    3. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
    4. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
    5. Slide the tray back in the printer.
  5. The tray 2 paper level indicator is stuck. (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00276974).
    1. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
    2. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
    1. Turn the printer off.
    2. Press and hold down the green GO button.
    3. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
    4. Release the GO button.
    5. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
  8. If the issue persists, please contact Hewlett-Packard's Customer Care phone center for further assistance. at http://www.hp.com/support.
Mar 12, 2008 | HP LaserJet 1320n Printer
Samsung CLP 315 Laser Printer Logo
23 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
