Question about Samsung Radio Communications
Hold to put the AACRD50CKE bluetooth model in pairing mode
My iPhone isn't recognizing the earpiece
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Make sure iPhone is discoverable. Power on the bluetooth device without letting go of the button for several seconds.
Posted on May 07, 2014
  • 12 Answers
SOURCE: need plantronics 320 pairing code
it's either OOOO or 0000.
Posted on Feb 18, 2009
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
  • 23 Answers
SOURCE: H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
Posted on Aug 19, 2009
  • 86 Answers
SOURCE: how to put motorola bluetooth in pairing mode?
Hi there - follow the step-by-step instructions here:
http://direct.motorola.com/eng/bluetoothselect.asp?country=GBR&am
Just pick your model and it will guide you through it;
Posted on Aug 29, 2009
SOURCE: My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Posted on Oct 19, 2009
When trying to pair my H730 with my phone I get the message "can't communicate with Motorola H730".
Sometimes pairing is hard but your phone especially Bluetooth device to your phone cell phone to not recognize your Bluetooth device may not pay very well with some phones I recommend a universal Bluetooth earpiece has high capacity to go with any model carry your phone1 only get you one or two
Oct 09, 2016 | Motorola Mobility H730 Bluetooth Headset
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do i pair with an iphone 3g
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Dec 23, 2010 | Samsung S3650 Corby blackwhite + WEP 490...
My uniden bt108 bluetooth headset would not pair with my new Iphone4. My Iphone 4 couldn`t even recognize my bt108.
Dec 17, 2010 | Uniden BT-108 Bluetooth Headset
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
My iPhone recognizes my Emerson 227 bluetooth but pin numbers will not connect using recomended codes 0000-1111-1234-9999 are there any other salutions my iPhone is 3g
Put the headset into pairing mode. First turn it off. Turn it on and hold the powerbutton down until the bluelight is not blinking then pair using 0000 as the pin.
Aug 21, 2010 | Emerson EM227 Bluetooth Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Jul 20, 2010 | Plantronics Explorer 330 Headset
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 | Cell Phones
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
187 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
ivan georgiev
ivan georgiev
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
