Question about GE Spacemaker JVM1640SJ Microwave Oven
Need a light cover; can't get to model number
I have a spacemaker so the model number isn't accessible; however, the light cover on the bottom is broken. How can I get a new one?
  • GE Master
  • 9,098 Answers
The model number should be on a tag inside the cooking cavity.
Once you find it, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jun 24, 2009
Relace bulbs ge spacemaker model JVM164OCj02 light that illuminates cooking surface of stove
That model would be JVM1640CJ02.
That is covered on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it here.
Always be sure you unplug power before you remove or install bulbs in a microwave.
Otherwise you may need circuit board repair.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker JVM1730 the turntable stopped turning. The next day it started to turn, but stopped. I tried cleaning the parts,but no help
If the oven is STILL heating, but the carousel isn't turning, the symptoms you describe are commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is either WB26X10233 or WB26X10038 (depends upon your COMPLETE model number). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The light bulb on the right side has burned out. How do I get access to it?
You can download GE owner's manuals and installation instructions here.
If the manual doesn't cover it, you'll have to remove the oven from the wall and take off the outer cover to get to it.
You can find handy exploded views and order parts by model number or part number here.
We are happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Sep 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse location ge spacemaker under the counter
it is behind the control panel.to access that remove the top grill by removing two screws on the top or in the fron of grill.then u should see see a screw on the top of control panel holding it.remove that screw and u should be able to remove the control panel.fuse will be behind the panel.it is not mounted on the panel but in the cavity behind it.
Aug 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing interior light bulb for ge spacemaker xl1800
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
hope this helps dont forget to rate this
Sep 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Sep 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Microwave, overhead household, Model 721-6264900
If you don't have your instructions, please reply back with your brand and model number.
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 23, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
