Question about Aeris Scuba Diving & Snorkeling
Where can I find parts for front cover of a purge button , alternate second stage?
Don't know the brand, CEO120EN250 written on plastic part, and a small sticker with 00356506 on it. There's a plastic screwed ring holding the cover, then the valve. Thank you.
3 Suggested Answers
  • 190 Answers
SOURCE: Sherwood Brut 1st stage parts
Please be a little more specific on needs, and I will look it up for you.
Posted on Feb 04, 2010
  • 36 Answers
SOURCE: the front cover of the 2nd stage is broken on
How about going to a Oceanic dealer? Eh? They should be able sell you the parts and install them. Remember, life support equipment should be serviced annually, and said replacements would be part of that service.
Posted on Aug 19, 2010
Where is the canister purge valve located on a 2005 Buick LaCrosse CXS with a 3.6 L
Remove the plastic cover off top of engine . purge valve solenoid under it.
Evaporative Emission (EVAP) Canister Purge Solenoid Valve
Top rear of the engine, on the intake manifold, near the fuel injectors. If you don't know what it looks like google part to see a picture .
Dec 31, 2016 | 2005 Buick LaCrosse
Where is the vapor can purge valve located on the 2007 chevy silverado 4.8l 4wd?
Under the hood in the engine compartment ! Google the part to see what it looks like > Does you truck have a plastic engine cover ? Remove it ,probably under there . Located behind alternator
Jan 02, 2016 | Cars & Trucks
It says i have error 5100 on the pixma ip2600 i got it from a friend and he didnt give the manual with it
Error Code 5100
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Also try:
Opening up the case so you can get to the side where the power pack is located and then disconnecting the small plug connecting it to the printer circuit boards, wait 10 seconds, reconnect the plugs again the printer and then re-connect the external power lead.
Also try :
Solution 1:
  • Clean the timing strip.
Solution 2:
  • The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough . Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Aug 18, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I have a canon mp250, it had a paper jam and now says error number 5100. Won't print, please help.
Also try:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 20, 2011 | Canon Pixma MP450 All-In-One InkJet...
I have an error code 5100
Error Code 5100
Also try:
Apr 15, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
OR Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
The front cover of the 2nd stage is broken on
May 16, 2010 | Oceanic Alpha 8/ Sport Regulator with Dry...
Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Mar 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Safe second?
"The second stage regulator takes the manageable pressure coming from the 1st stage through the hose and delivers it to your mouthpiece in a way that is comfortable to breathe. Where the 1st stage is only concerned with letting air flow into the hose the 2nd stage has more complex machinery which handles both inhaling and exhaling through the same mouthpiece. Like the first stage the 2nd stage scuba regulator uses a diaphragm or piston to open a valve. Breathing in from the mouthpiece reduces the air pressure inside the chamber, water pressure pushes the diaphragm in, which opens the intake valve. When you stop inhaling the pressure in the chamber balances and the valve closes. The result is an air delivery system which supplies air only when you are inhaling and does not leak air constantly through the mouthpiece. A well balanced and well-maintained scuba regulator does its job so well that breathing feels natural and effortless despite the all mechanics involved. The second stage scuba regulator also has a purge or exhaust valve, which lets your exhaled air out of the chamber, but doesn't let water in. When you exhale into the second stage scuba regulator the pressure inside the chamber becomes greater than the ambient pressure. The exhaust valve is a simple one-way valve which lets this air escape. The second stage scuba regulator also has a purge or exhaust valve, which lets your exhaled air out of the chamber, but doesn't let water in. When you exhale into the second stage scuba regulator the pressure inside the chamber becomes greater than the ambient pressure. The exhaust valve is a simple one-way valve which lets this air escape. A second stage scuba regulator also has an ""emergency"" or ""purge"" button which forces the intake valve to open. When the purge button is pressed air will flow continuously into the chamber and escape either through the mouthpiece or the aforementioned exhaust valve"
Dec 01, 2008 | Aeris A1 Octo
Front cover is open
the door of your printer have a micro switch ,on the door you have a some plastic part that prees that switch,try to find it and then put some plastic on the top .
Feb 01, 2008 | Brother MFC-9420CN All-In-One Laser...
Scuba Diving & Snorkeling Logo
113 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
