Question about Lands Phones
Where can I find Nautilus Parts for NR 1000 . . heart rate handles
Nautilus 1000 NR needs Metallic Heart Rate Sensor, Sensor part is located in handles. Nautilus says no longer available.
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Posted on Jul 03, 2009
escapement
  • 2334 Answers
SOURCE: don't know how to turn on heart rate monitor
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals.Rate me, please.
Posted on Mar 25, 2010
escapement
  • 2334 Answers
SOURCE: how do you turn on the heart rate monitor on a
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Posted on Apr 20, 2010
  • 155 Answers
SOURCE: Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
Posted on Jul 15, 2010
SOURCE: garmin edge 305 heart rate sensor does not work
the rescan worked for me, didn't know it existed, briljant. Follow list below:settings/system/accessoires/rescan
I love google today;o)
Posted on Dec 09, 2010
What is a normal heart rate?
53 to 54 is low, going below 50 is an alarm condition for a EKG monitor - been there, done that!
Jun 05, 2016 | Exercise & Fitness
The heart rate monitor chest strap no longer works and I need to buy a replacement. Which are compatible ?
Maybe you can find a replacemente. Do a google search for terms
Heart rate Monitor, the make, model and PARTS
If can't find, do a search for Manufacturer's website and try to get information from some "Contact Us" option. Some even have a phone number.
A shot in the dark:
Accessories Polar USA
Polar Transmitters Straps and Heart Bras
heart rate monitor parts Google Search
Elastic Strap for Heart Rate Monitor Garmin
Sep 01, 2015 | Exercise & Fitness
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
Irregular reading from heart monitor
The most common reasons for this are poor contact with the chest strap and signal interference.
If you visit my tips and tricks page there is a step by step trouble shooting guide for heart rate monitors.
If you are not using a chest strap, but instead using the hand grips for HR, this is another issue.
Most common with hand grips is gripping too tight or your grip is somehow not making good contact with the handle. handle grips are not as accurate as chest straps as they are more reliant on "how" you grip the sensor. Also moving around your hands while gripping will cause problems.
finally - if all these things are satisfied, you may just have a weak sensor or problem with the maching itself.
Dec 20, 2010 | Nautilus Nr Recumbent Exercise Bike
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
Dec 12, 2010 | Polar F4 Heart Rate Monitor Watch
How to turn on the heart rate mode of solo 915 sport line watch?
Please make sure you are in time mode. Now hold your bottom right button in for 2-3 seconds. You will see a heart pop up over the seconds. Now you will be able to take your heart rate.
Jan 20, 2010 | Sportline 1000 Memory watch
Garmin edge 305 heart rate sensor does not work
Mar 21, 2008 | Garmin Edge 305 GPS Receiver
Lands Phones Logo
41 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
