Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
Malibu Light Transformer ML121RT troubleshooting
My light string doesn't light up...it did. The clock device continues to turn, I can hear it. Manually turning the lights on and off with the little switch does not turn the lights on and off. There are three terminals on the back and the lights are connnected to A & B. I have a volt meter...how do I see if there is any voltage coming out of the transformer?
1) Disconnect the plug.
2) Remove the 3 hex screws holding the cover.
3) Make a note of all connections (taking a picture is even better).
4) Connect the black power wire to the red transformer wire.
5) Connect the white power wire to the white transformer wire.
6) Set your voltmeter to 20 or 50 volts AC (not DC and not less than 15 volts).
7) Plug the transformer in the wall.
8) Test the voltage coming from the A & B connectors at the back (polarity is irrelevant).
If you see 12 volts or thereabout, the problem is with the little switch (the one with the black and red wires that is activated by the trippers on the clock dial). I have the exact same problem but I have been unable to locate the part so I am going to try to clean the contact points and see if that works.
Posted on Aug 09, 2009
  • ccss Aug 09, 2009
    Cleaning the switch worked for me so I am back in business.
    This post is to explain how to test/clean the switch:
    1) Review the earlier post to open the box and disconnect/reconnect the wiring safely.
    2) Set your test meter to ohms (resistance, omega sign).
    3) Test your meter by making a contact (short) between the 2 probes: the needle should go all the way to the right. If not, follow the instructions in your test meter manual for using it as an ohmmeter.
    4) Make sure that your transformer is unplugged from the wall.
    5) Connect one probe to the switch red wire and the other one to the switch black wire.
    6) If you don't get any reading, try flicking the switch manually and try again.
    7) If you don't get any reading with the switch turned on or off, the switch is faulty and needs cleaning and/or replacing.
    8) Bend the black plastic tabs back gently and remove the switch by pushing on the little black knob on the outside of the cover plate. This will expose the contact points.
    9) Rotate the little black nob to open the contact points and clean them by blowing air gently, being careful not to damage them. Cover the points with dialectic grease to avoid further problems.
    10) Repeat steps 4-6 to verify that the switch is working. If that fails, replacing the switch is the only solution.
    I will post another solution if I ever figure out what the part number is.
    President:
  • 1,723 Answers
On your 'AC volts' scale go to terminals A & B when turned on. Should be 12 volts. If there is, check connections to lights. Make sure your trippers are in place on dial.
(Terminal C is for photo cell control)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 26, 2009
One terminal for wire attachment on transformer appears burnt. Fixable or replace?
Something happened to the unit.
Good news is that lights are still ON.
Might be power surge. Or extra wire wrapped around transformer.
Clean up terminal with sandpaper.
If clock motor does not rotate, but lights are ON, then plug power pack into cheap wall timer.
Copy following link and read tips for getting power pack to last longer. One of these reasons may apply to problem.
Plus view warranty, and replacement trippers.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 04, 2012 | Intermatic Malibu 121W Power Pack...
Malibu transformer ml44p doesn't turn off
Check if trippers are worn.
Check if dial rotates and keeps good time.
Plug transformer into cheap wall timer.
Copy following link for trippers, 5-year warranty info, tips to make power pack last longer, and other troubleshoot resources:
Oct 30, 2012 | Intermatic Malibu 121W Power Pack...
I have a malibu set of 8 lights about 80 foot of 12 gauge wire. They come on then after about an hour they shut off then come back on about 20 min later
Do you have photo-eye connected to the transformer?
Disconnect photoeye, or cover photoeye with black tape and see what effect it has.
Plug another light into same outlet and see if it has same problem.
Run temporary extension cord to transformer and see if problem is same.
When the lights are off, does the transformer make humming sound.
Intermatic/malibu timers have 5 year warranty if you have sales receipt.
Copy following link for troubleshoot resources, trippers, operation tips, etc.
Aug 15, 2012 | Malibu Intermatic Inc. ML121RT Low...
Describe your Malibu 121W Power Pack Transformer ML121RT Problem my unit just fryed itself as I had a underwater light hooked up to it. however it took 3 years for this to happen plus I think I had more...
Power pack wattage has to match bulb wattage, or it shortens life of power pack.
I don't know physics and electrical engineering enough to know why this happens.
Also when working on bulbs, manual says to unplug power pack so it doesn't burn up.
If bulb is under water that's fine, but wiring cannot be underwater where it shorts out, or suspect this action might also shorten life of power pack.
With receipt, power pack could still be under warranty.
Open following link for power pack resources, and links:
Aug 23, 2011 | Intermatic Malibu 121W Power Pack...
Had to replace a fixture today. when I replugged the lights the lights turn on manually but the clock on the timer does not advance I have 56 watts of light Is the timer broken?
If clock motor does not rotate, then some people report taking it apart and cleaning gears.
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Nov 29, 2010 | Intermatic Malibu 121W Power Pack...
I have a malibu ML121RT timer that just stopped working. Outlet works, new lightbulbs, didn't nick power cords to outdoor lights. What could be the problem?
If transformer no longer works, then it is not repairable.
Jun 16, 2009 | Intermatic Malibu 121W Power Pack...
What timer motor fits in Intermatic ML121RT Power Pack ?
Apr 11, 2009 | Intermatic Malibu 121W Power Pack...
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
5,813 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Rob Sinbad
Rob Sinbad
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
