Question about Dryers
Can you clean or get replacement filter for ARIEG model CT298TF tower fan?
How do I clean my clean living tower fan?
Usually there would be a few screws in the base that need to be taken out and the outer case pulls out. This will expose the fan and filters inside. Hopefully that will allow you to clean the inside. Would not spray any cleaning agents. Just a light vacuum and wipe with clean moist cloth.
Aug 27, 2014 | Tower Dryers
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
Owners manual for Enviracaire EFY-047? Remove filter? Thanks
I believe this is the correct Use and Care Manual for your fan:
http://useandcaremanuals.com/pdf/BDTF1010275.pdf
Simply clean the vents with a vacuum cleaner; you should not need to remove. There is no filter in the Black & Decker BDTF1010 Tower Fan.
Apr 18, 2011 | Black & Decker BDTF1010B Tower Fan
Is the best way to clean a tower fan with air? it doesn't disasemble very easy. It does have a cleanable fiter right?
No filter, what I do is spray tthrough the grill with Mr Clean generously.
Let sit for 20 mins. Take outside and turn on hi.
Jun 24, 2010 | Tower Aloha Breeze Fan
How to dissamble to clean aloha breeze tower fan model 87001
I just used an air air compressor with a soft rubber tip and went at my two tower fans outside. It took maybe 10 minutes shooting air in from many different points but both fans now work as good as new. If it's been a couple of seasons like mine you'll be amazed at how much blows out.
May 14, 2010 | Tower Aloha Breeze Fan
How do you clean a tower fan?
How do we clean the Lasko 2554 tower fan filter please some one help email me at dutchlady_49@yahoo.com
May 05, 2010 | Lasko 2554 WIND CURVE Fan
How do you clean it? It shoots out dust!!
You need to change the air filter, make sure you clean out the air filter chamber before installing a new one. it should be fine then, Good Luck
Feb 07, 2010 | Seville Classics MSC10166 Tower Fan
BIONAIRE BCM630 TOWER HUMIDIFIER stopped working
If you would like to buy a new tower without a tank, I will be happy to sell mine.
Aug 24, 2008 | Bionaire BCM6010 Humidifier
Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
Jan 16, 2008 | Holmes Products HCT460-U Utility Heater
Cleaning
cleaning the tower fan consists of this, i took the time to figure it out! unscrew top two screws on back of tower fan. then on bottom of tower fan is a screw cover,(pin size hole in middle of circle) pull cover off. unscrew hidden screw, and now with a little force it should pop right off. it exposes the filter and all it interior. front screen does not come off. oh yeah,your welcome!
Jun 08, 2007 | Tower Aloha Breeze Fan
Dryers Logo
48 people viewed this question
Top Dryers Experts
