Question about Leisure Cookmaster CM101NR
Glass lid? Glass lid moved,how to take apart
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
These are tricky, first remove all burners trivets knobs etc so there is nothing at all left on the glass top then you will need two small screwdrivers gently using them like tyre levers work around the edge and it will usually just lift off, when replacing it make sure that everything is lined up properly.
Posted on May 08, 2014
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
MY HP 8500A HAS STARTED PRINTING WHOLE PAGE BARCODE LOOKING LINES WHEN I PRINT OR COPY IN BLACK. COLOR LOOKS GREAT. IVE CLEANED THE PRINT HEADS AND ALIGNED THEM. ANY OTHER OPTIONS? THANKS
Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Lift the scanner lid. Figure 3: Lift the scanner lid
  4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
    CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
  5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
  6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
  7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
    NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
  9. Close the scanner lid.
  10. Reconnect the power cord to the rear of the product.
  11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  12. Try to copy, fax, or scan again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove any documents from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
  6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off the separator pad.
Aug 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
Glass cover exploded in millions pieces.luckily nobody got hurt.
energy from tightening the screw on the plastic cover of the glass lid, resulted in a series of molecular transitions, that reacted with the metal around the glass to produce the shattering of the lid. amazingly producing a new source of energy that should be investigated. the company should recall all glass lids asap, and exchange them with some inert cover material. someone may be seriously injured.
The glass lid on our unit exploded yesterday scaring the heck out of my wife who is still picking glass out of
Jan 14, 2011 | Rival WS60T Non Stick Electric Wok
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
Need plastic handle on Rival Crockpot lid.
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
Lid Issue
Hi, Same issue, the options you have are, 1) Now there available in market are the no-glass-lids you may find and buy just the lid. 2) Go to a window-glass shop and get one cut in the same measurement and fix it, but this is risky one as the glass may brittle for less pressure depending on the quality of the glass 3) as I couldn't find option 1(in Gurgaon) and option 2 failed, I took a microwave suitable plastic plate, and cut(siccissors) it in the same shape and replaced with it within the screws, and its perfect.
Feb 20, 2009 | Panasonic SR-W06NA 3-Cup Rice Cooker
HP 7410 Scanner mirror dirty
you can go tru this extract ON HOW TO FIX IT
clean the glass
Dirty glass, from fingerprints, smudges, hair, and so on, slows down
performance and affects the accuracy of special features such as Fit to Page and
Copy.
1 Turn off the unit, unplug the power cord, and raise the lid.
2 Clean the glass with a soft cloth or sponge slightly moistened with a
nonabrasive glass cleaner.
Caution! Do not use abrasives, acetone, benzene, or carbon
tetrachloride on the glass; these can damage it. Do not place
liquids directly on the glass. They may seep under it and damage
the unit.
3 Dry the glass with a chamois or cellulose sponge to prevent spotting.
clean the lid backing
Minor debris can accumulate on the white document-backing located
underneath the unit’s lid.
2 Clean the white document-backing with a soft cloth or sponge slightly
moistened with a mild soap and warm water.
3 Wash the backing gently to loosen debris; do not scrub the backing.
4 Dry the backing with a chamois or soft cloth.
Caution! Do not use paper-based wipes as these may scratch the
backing.
5 If this does not clean the backing well enough, repeat the previous steps
using isopropyl (rubbing) alcohol, and wipe the backing thoroughly with a
damp cloth to remove any residual alcohol.
clean the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off the case.
The interior of the unit does not require cleaning. Keep fluids away from the
interior of the unit as well as the front panel.
May 14, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Leisure Cookmaster CM101NR Logo
146 people viewed this question
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
