Question about Amana ARGS7650SS Gas Kitchen Range
Oven does not heat. Glow bar ignitor glows but no flame.
I set the oven, it heats to 100, sometimes higher, but does not get up to temp. The glow bar ignitor glows but a flame does not catch. What other part could need replacing?
  • 530 Answers
Usually this means that your ignitor is weak and needs to be replaced. When the ignitor glows and NO gas flows through you need a new ignitor.
Posted on Jun 22, 2009
What is a glow bar ignitor
Next to the burner in the oven sits a ceramic igniter. When you turn the oven it glows orange which ignites the flame. It stays on even if the oven is at temperature and the flame if off. There are 2 wires going to it and its connectors are in a part of the oven away from the heat and flame. They do burn out. There is no reset. You have to replace it.
Oct 30, 2017 | Ovens
JGSP48SHSS oven
if it gas and the bake isn't working correctly,first thing that usually goes is the ignitor,sometimes the ignitor will glow but won't lite the flame,it works on amps. a flat ignitor takes 3.2 amps to open the gas valve a round one os 2.5 amps.so the easiest way to check it is start the oven,if you can't see the ignitor glowing orange then remove the racks and the floor of the oven so you can see it,when the ignitor starts to glow it should ignite the flame within 40 seconds,if not change out the ignitor,if the ignitor doesn't glow then you need a meter to check it for continuity,disconnect the ignitor wires and check it with a meter,set it on say 20k ohms,touch the leeds to the ignitor wires,if it stays on 1 then the ignitor is bad,if you get any other reading other than 1 then it's good and you have a problem somewhere else but like i said most of the time it will be the ignitor.
Dec 04, 2011 | GE JGSP48SHSS Gas Kitchen Range
When we turn on the broiler or the oven it will not heat up inside. The warmer drawer works. The screen is fine and its like it will heat up but stays at 100 degrees. Is this the ignitor switch? or is...
Hello, Thank You for using FixYa. I will be helping you today.This sounds like an ignitor issue.When the ignitor starts to fail it will glow enough to add heat to the oven or the default for the oven is 100 degrees.The ignitor is located under the bottom inside the oven,Sometimes it will glow but it dont let enough power through to open the gas valve. I would say its an ignitor issue.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kitchen Ranges
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=
partimage.aspx?imgid=z3bqljbfbxnfodk0nzawndcvq0fnl3nvdg9ochryyxav
show?id=yo6223wzsty&bids=142421.661381148&type=10&subid=74007498
Sep 28, 2010 | Ovens
GE gas oven--Spectra--the oven does not heat--the broiler works, however
Most common problem is the glow bar ignitor. Lift off the bottom panel of the oven and remove. (Some have two screws holding the panel at the back of the panel.) Turn the oven on and see if the glow bar glows.
Even if the glow bar glows doesn't mean that it is working 100%. An amp probe is need to see if the glow bar is drawing the proper amperage to allow the gas valve to open allowing gas to come to the burner. The glow bar should draw about 3.5 to3.8 amps. If drawing more or less than this, replace the glow bar ignitor.
I hope this helps.
Jan 25, 2010 | GE Ovens
Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Jun 24, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ge Spectra
Remove the bottom of the oven you will see 2 screws in the back. once you do that there is a flame baffel on top of the burner held on my one screw. remove that. now turn the oven on and watch to see if the glow bar comes on. I would say it wont or if it dose it is to weak to open the gas valve. Replace the glow bar and you will be back in business. the glow bar is a ware item everytime theoven is on and is heating the glow bar is on . good luck
Jul 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana ARGS7650SS Gas Kitchen Range Logo
606 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
