Question about Cuisinart Furniture
Cuisinart wine cooler won't cool - Cuisinart Furniture
3 Suggested Answers
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
The system will not cool and want to replace the refrigeration parts, all else seams to be working fine
I have a Cuisinart Model CWC900 wine cooler that stopped cooling -- the cooling module is bad.
The FIX.
1. First remove the filler plugs from the screw access holes. I did this by tapping the plug off center with a small screwdriver and a small hammer. The plugs popped right out.
2. Use a #10 Torx driver to remove the screws from the holes.
3. The chip on my cooler was a TEC1-12708 made by HB. The part # was on the chip. I found the chip information by doing a Google search on the part #.
4. I found a replacement chip from Custom Thermoelectric. The part # to replace the chip in my cooler was P/N 12711-5L31-09CQ. Cost is about $20. You should specify that the chips that you order should be 'Sealed'. The lady that I spoke with said that the chips last about two years. The people at Thermoelectric were very helpful and appeared to be very knowledgeable.
5. You should apply heat-sink grease to both sides of the chip before installing the chip.
I hope that this helps.
WGD
Jan 22, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Furniture Logo
217 people viewed this question
Top Cuisinart Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
