Question about Saws
I need to replace my power cord on a Milwaukee 4096 dymodrill
    Problem Solver:
  • 17 Answers
Check to see if any of these work for your drill. There are some cords in the search results that seem universal for Milwaukee drills.
Milwaukee 4096 dymodrill power cord
Posted on Jul 01, 2014
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
http://documents.milwaukeetool.com/58-01-0930.pdf
May 06, 2014 | Drills
My dog chewed up cord. How do I repalce Milwaukee Model 6507 Sawzall
this should be a twist lock cord and all you need to do it twist the connector at the handle area and pull the cord off and buy a replacement, make sure whether it it grounded (3 wire) or double insulated (2 wire), you can go to Milwaukeetools.com and with your serial number look at a schematic for this tool and they also have a dealer locator to ensure that you get the proper one. Let me know if you need more assistance.
Sep 19, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
When I turn on the router, there is no response at mosttime, although sometime it works.
Do a check on your cord, a bad cord can cause that, either that or the power switch is missing contact and may need replaced.
Mar 06, 2011 | Milwaukee 5619 29 Router Motor 1 3/4 Max...
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
I need to change the cord on my 9392 Milwaukee Drill. The trigger does not have any screws and, I cannot not see how to change the cord out. The ground wire is attached to a screw connector.
On the trigger switch, if you look really closely you will see that there are clips inside where the wires go in. If you use a jewelers flat screwdriver or other narrow flat instrument, you can push the clip back enough to release the wire.
If the replacement cord doesn't have clips on the ends of the wires, make sure that you tin (apply solder) to the ends of the new wires before inserting them into the trigger. This is needed to keep the individual strands from being pushed everywhere and causing a short, and stiffens the end, making it easier to insert.
If you need further assistance, let me know.
If this was helpful for you, please rate the solution.
Apr 20, 2009 | Milwaukee Tool Drills
New switch
OK make a drawing of the back of the switch, you should see 5 openings 2 already with wires in them. From back upper left is black supplied with switch upper right is yellow from the field middle is also a black supplied with switch lower left is black from the power cord and lower right is white from the power cord. Let me know is any more problems
Jan 21, 2009 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Shaft has no power.
In the old days I would have said "Check the shear pin." But I just looked at the breakdown for this tool and it looks like they have put a clutch in this tool. The gear box will have to be disassembled and the clutch will have to be inspected and if the parts are still good, the clutch will then need to be torqued to the proper foot pounds. I hate to say this but, this is probably a job for a repair shop.
Dec 03, 2008 | Milwaukee 4096 Diamond Coring Motor...
Barrel won't turn
by barrel I take it you are talking about spindle? This might be the version that has an internal clutch mechanism that would require you taking it in for service. If not there is a shear pin in the spindle that might need replaced. Hope this helps
Saws Logo
98 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
