Question about Logitech Driving Force GT Wheel for Playstation 2, PlayStation3
Why my brake pedal stays stuck until i pump it ?
My guess is there is a piece of plastic either on the pedal or the case that is rubbing. If pumping the pedal makes it work then the spring is probably okay. A small piece of plastic flashing from when the parts were molded may have dislodged and is causing the pedal to hang up. When you pump the pedal you are causing the small piece of plastic to bend out of the way. If you cycle the pedal enough the piece of plastic will likely break off. Sort of like breaking a soda can in half. If you bend it back and forth enough times it will eventually break.
Posted on May 17, 2014
2000 electraglide, trying to bleed brakes on the rear master cylinder. I take the cap off master cylinder put a hose on bleeder valve, pump up break and hold it down crack the valve and nothing comes out....
does the pedal have pressure then go down after valve is cracked? With a hose on the nipple to a bottle to catch the fluid, press rear brake pedal down. Don\'t pump the brakes. Crack the bleeder valve while continuing to press down on the pedal. Once the pedal reaches the limit of its travel close the valve. Once the valve is closed; and not before; release the pedal and let it return to its at rest position. Repeat this process until you have good pedal without the need to pump, good clean fluid is coming out the valve, and no air is in the fluid coming out the valve. Be sure not to let the fluid in reservoir get too low or you will suck in air and need to start over and don\'t press the pedal too quickly or you can shoot a stream of brake fluid out the reservoir.
In very extreme cases, if you have lost prime in the master cylinder, it may be necessary to bleed the master cylinder first. THIS IS A LAST RESORT. Remove the brake line from the master cylinder. Try to limit the loss of fluid from the brake line to bare minimum. Thread a nipple into the master cylinder. Run a hose from the nipple into the reservoir. Be sure the hose stays submerged in the fluid in the reservoir and pump the brake until no bubbles come out the hose. Remove the nipple and reinstall the brake line. Slowly press down the brake pedal while tightening the line to minimize the air bubble in the brake line. Again be sure not to release the pedal until the line is tight. Then proceed to bleed the brakes as you normally would. Do not pump the brakes up. Just press the pedal down, crack the valve, close the valve, release the pedal, repeat.
Aug 24, 2014 | Cars & Trucks
Brake pedal stuck down
Pull the pedal back up as the problem is air in the system. You may have to do this until the air starts to move out of the system. IT would be advisable to prime the master cylinder before fitting it as this overcomes the problem of trying to get the cylinder to pump up.
Nov 17, 2013 | 2001 Dodge Ram 3500 Truck
Brakes on Chevrolet Optra soft and brakelights will not stay off - have had master cylinder replaced - problem getting worse. Have had lines bled.
Did you bleed air on ur BRAKE MASTER? Brake lights stays, must've the BRAKE switch on your pedal area is STUCK UP! Either its been damage when ur pumping ur brake during bleeding! Check that! Tahh!
Nov 08, 2010 | Chevrolet Aveo Cars & Trucks
99 ford expedition, abs light stays on, front brakes seem to be dragging
When was the last time you changed the front brake pads?
Try this:
Keep the brake pedal pressed down and start the car, after it idles for about 10 second let go of the pedal. If the light comes on just as you leave the pedal - try pumping it a few times, turn the car off and pump the pedal some more until it becomes real hard.
Then, keeping your foot to the pedal, start the car.
Idle for about 10 seconds, let go of the pedal and press it again rel fast.
If the light doesnt come on again - it means you have a leak of some sort or that the main brake pump should be replaced.
Good luck.
Jul 11, 2009 | 1999 Ford Expedition
Brake lights stay on when car turn off
brake light switch stuck or bad
Feb 03, 2009 | 1999 Nissan Maxima
Brake problems
still got air bleed more
Nov 02, 2008 | 1993 Buick LeSabre
2003 Nissan Sentra Brake lights stay on
When you depress the brake pedal, the brake pedal will move away from the brake light switch and cause a close circuit and the brake lamps light up. There is a rubber bunk on the pedal which pushes against the brake light switch to shut it off when you release the brake pedal. Most likely this rubber bunk has either fallen off or disintegrated leaving a hole in the brake pedal so there is nothing to push against the switch to shut it off. Look up the brake pedal until you see the brake light switch, then depress the brake pedal to see if the rubber bunk is still there. It is easy to replace. Or you can use some double sided adhesive tape and a coin and stick the coin over the hole in the brake pedal.
Oct 02, 2008 | 2000 Nissan Sentra
Logitech Driving Force GT Wheel  for Playstation 2, PlayStation3 Logo
54 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
