Question about Car Audio & Video
My bush z7766 speakers ain't working they just stopped an all the wires r in
  • 36 Answers
Remove the speaker and test it with a aa battery and a piece of speaker wire. when briefly connected the speaker will make a clicking noise. if the speaker is good its your head unit.
Posted on Jun 20, 2014
Bush TV LE-20GY15T+DVD How do I connect external speakers to this TV ?
Unless the TV itself has separate speaker outputs, then you will have to work through an audio receiver which can be hooked up to run the audio signal through the unit and into speakers.
Mar 25, 2015 | Bush Televison & Video
My Akira Pedestal Fan stopped working suddenly
the major problem with fans is the bronze bushes that the armature runs in get dry from use and seize on the shaft. IF you are capable get to the bushes and you may find a piece of felt next to the bushes . Put some machine oil into the felt and spin the fan with your finger until it loosens up. Otherwise scrap it
Dec 08, 2013 | Cars & Trucks
Front door speakers stopped working
more than likely the speaker wire
Aug 21, 2013 | Toyota Cars & Trucks
I bought my elderly dad a bush TV for his birthday. I tried to plug in a set of headphones but also need the sound to come out of the speakers at the same time as my mum also needs to hear the TV. I
Get a cheap set of PC speakers and a headphone jack splitter.(the old TV apparently was designed to not turn the speakers off when you plugged in headphones).
Sep 16, 2012 | Bush Televison & Video
My Velodyne CT150 was distorted for a while. Then the sound is completely gone. I checked the speaker, but seemed to be working. What could be the problem?
Define "seemed to be working". Is it or ain't it? A huge clue that something is in distress or having death throes would be distortion.
Either the driver is hot or the amp is shot. You can test the driver by floating it from the amp and attempting to drive it with any other amp channel, or just touch the speaker leads to a small battery. It will click or make static sounds.
Oct 27, 2011 | Velodyne CT-150 Speaker
Sudden loss of sound on my Bush 32 inch HD ready TV
Hello Check first the volume setting, then if there's not ok,check the speaker.Remove the back cover and check the speaker if good or not.If the speaker is good check the wirings and connector terminal of speaker through the sound amplifier.If all is ok,then the problem is the sound amplifier.
Sep 08, 2011 | Bush Televison & Video
I need leads to connect my NAD C320 BEE amplifier to PSB T45 speakers. Not sure which plugs are needed to fit into the speakers.
From the C320 manual, Page 5...
11. SPEAKERS
Speaker terminals for speakers with an impedance of 4 ohms or more. Connect the right speaker to the terminals market 'R +' and 'R-' ensuring that the 'R+' is connected to the '+' terminal on your
loudspeaker and the 'R-' is connected to the loudspeaker's '-' terminal. Connect the terminals marked 'L+' and 'L-' to the left speaker in the same way.
Always use heavy duty (16 gauge; 1.5mm, or thicker) stranded wire to connect loudspeakers to your NAD C320. The high-current binding post terminals can be used as a screw terminal for cables
terminating in spade or pin sockets or for cables with bare wire ends.
BARE WIRES AND PIN CONNECTORS
Bare wires and pin sockets should be inserted into the hole in the shaft of the terminal. Unscrew the speaker terminal's plastic bushing until the hole in the screw shaft is revealed. Insert the pin
or bare cable end into the hole and secure the cable by tightening down the terminal's bushing.
Ensure bare wire from the speaker cables does not touch the back panel or another socket. Ensure that there is only 1/2" (1cm) of bare cable or pin and no loose strands of speakers wire.
Register and download the PSB manual for free at retrevo.com
http://www.retrevo.com/support/PSB-T45-Speakers-manual/id/23107ag412/t/2/
If you're pondering those jumpers on the back of the speakers, my advice is to leave them in place and ignore them. Connect the speaker cables to either plus or minus.
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Apr 15, 2011 | PSB Century 600i Speaker
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
