Question about Kyocera Office Equipment & Supplies
How do I resolve error code 7003:0200313?
The printer in my office is no longer under warranty and it will cost $135 just for a technician to come LOOK at the printer. I am a bit of a computer geek and a third generation electrician's daughter and can generally take apart machines to fix them. What is this error code though?
  • 641 Answers
Hi Leahray09,
You might be referring to the error code C7300 which is for Toner sensor problem. Try to check this site and perhaps the error you are looking for is there.
Kyocera Mita Error Code Messages
Posted on May 06, 2014
5 Suggested Answers
  • 212 Answers
SOURCE: The pickup tray does not pull in paper and
clean the feeding roller
Posted on Mar 11, 2011
ferow_18
  • 24 Answers
SOURCE: my printer will not print.
Hi there, regarding with the problem that you have..the error message that you are encountering with that machine is something about to work on with the printhead..because the printhead is the one causing the problem why is that the error message keeps on popping up, i believed that the printer model that you have is already out of warranty..the printhead is not replaceable if the printer is out of warranty.. well in that case, quite frankly the printer is already faulty.
you can definitely call HP by dialing this number 1-800-474-6836 and let them see what they can do in their end..
Thanks!
Posted on Aug 04, 2011
  • 42943 Answers
SOURCE: ---HP LaserJet 4 Plus. Replaced the rollers to
The HP LaserJet 4 series is so old HP does not even stock overhaul kits for it. It may be time to turn the old workhorse out to pasture.
Posted on Nov 01, 2013
Canon c1028i error 000100 solution
For resolving this error code you need to connect with the Expert technicians of Canon Printer Support team.They will guide you efficiently to get out of the issue that you have been facing.This is just a Call away, You just need to Dial 1-800-243-0019 Canon printer Support Number for proper assistance.
Sep 05, 2017 | Canon Office Equipment & Supplies
Xerox error code 062 371
By Dialing 1-800-243-0019 Xerox printer support number you can easily Fix Xerox error code 062 371 under the guidance of expert technicians of Xerox printer team. We are here for your support 24*7.
Apr 23, 2014 | Office Equipment & Supplies
Code error 24:10
ISSUE: The printer front panel displays System Error 24:10. The printer may not print, and in rare cases, ink may leak from the printer. SOLUTION: HP is investigating a recent issue with some HP 91 Ink Cartridges in HP Designjet Z6100 series printers. A combination of factors related to handling during shipping have resulted in a very small incidence of HP 91 Ink Cartridges with the System Error 24:10 error. When the problem occurs, the printer front panel displays System Error 24:10 and the printer may not print.
HP regrets any inconvenience this may cause. Please contact HP Customer Support for assistance. Click here for information on how to contact HP support at http://welcome.hp.com/country/us/en/wwcontact_us.html.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
Removing the error H4-00 code
In Toshiba Printer the error codes generally occur due to instability of drivers in system and also due to system related issues either it is supporting or not .So for proper assistance on this issue just get connected at Toshiba Printer Support Number 1-800-243-0019 and get in touch with expert technicians and get your issues resolved. Visit: Toshiba Printer Support Phone Number 800 243 0019 for Help
Aug 27, 2012 | Toshiba e-studio 203sd
I get this error code in hp 1312 error cod 51.23 what can i do i wait your answer best regard
Turn power off. Unplug printer. open and close firmly every door, hatch, panel, and drawer. Verify all toner cartridges are full. Verify that no paper is jammed in the mechanism. Power printer back on.
Aug 20, 2011 | HP Laserjet CM 1312NFI Color Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Error message F-28 and F-21 on an He2 Plus Washing machine Under warrantee
"F28" is a Serial Communications error code. This is an interruption in communicaitons between the Central Control Unit (CCU) and Motor Control Unit (MCU, or the interconnecting wiring between the two.
"F21" is a Long Drain error code. This is usually an indication that something is restricting the drainage system. Commonly, the drain pump reservoir, or inlet line running from the wash tub to the drain pump is clogged.
Since your washer is currently still under warranty, I would strongly recommend you call for service and have a technician resolve these issues for you. Any attempts on your part to disassemble the washer and make any repairs may void your warranty.
The "F28" error code in many cases is caused by a defective CCU which would need to be replaced. Replacement cost (if not covered by warranty) can exceed $200. The "F21" error code, in a worst case scenario can be caused by a drain pump failure. Replacement cost (without warranty) can exceed $150. If the washer is still under warranty, and if any of these parts are found to be defective, they should be replaced at NO cost to you. Honoring your warranty makes better sense in this case.
For a full explanation of these error codes, you can refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
NOTE: Removing the toe panel to retrieve the tech sheet does NOT constitute disassembly and should NOT void any warranty coverage.
If you have any questions/concerns, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | Kenmore HE2 Plus Front Load Washer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Epson cx8400 printer error
In order to fix error code cx8400 on Epson Printer, make sure that you have removed the cartridge once, and then place it back again. If you don't know the process, you can take help of the manuals given to you along with the device. And, if by chance, your issue is not resolved even after resetting the cartridge, it is important for you to take instant help from the experts. Just call them now on Epson printer support phone number to connect with the professionals, and they will quickly resolve the problems.
Jan 31, 2009 | Epson CX8400 All-In-One InkJet Printer
106 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
