Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is full of water and will not go away, what to do?
Water is not pumping the water out of the machine?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Whirlpool Expert
  • 154 Answers
Washer has a bad lid switch, replace lid switch
Posted on May 06, 2014
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    What is pump out for & how does it work
    does your machine have a rinse cycle that requires the dirty water to leave the machine and then to have clean water fill the machine that then rinses the colthing of detergent and dirty water that then needs to be pumped out. Then does it have a spin cycle that extracts the water out of the items and needs to pump out excess water do clothes have water extracted out of them ?
    A pump connected to a motor via a belt spins the pump turbine and pumps out the water.
    Aug 06, 2015 | Washing Machines
    My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
    Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
    Jan 25, 2014 | Washing Machines
    Scotsman sc275 water pump not recyling water, water pump motor gets hot, machine shuts off.
    If the water isn't recycling I would pull the machine out and take the back cover off. Remove the wires that go to the pump, plug the machine in and then with a volt meter measure the voltage and make sure you have 115vac. If so then change the pump. The part that concerns me is that you say the motor gets hot and shuts off. Are you still referring to the pump or do you mean the compressor at the bottom?
    Jun 17, 2012 | Scotsman Refrigerators
    Water leaks from machine during use. Have checked filter on right near base is clear.
    Sounds like the water pump is going bad or a hose is leaking. Replace the water pump which in most cases are not, too costly. Most water pumps can be replaced from the bottom of the machine. If you can not find the part # on the water pump, look it up by the model # of the machine.
    Aug 22, 2011 | Washing Machines
    My washer can wash but cannot drain water from thye tub. how can i fix this?
    The question is pretty loose so I will do the best I can without knowing the model and type of washer but they are all basically the same.
    If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
    Blockages are the more likely explanation, but pumps can fail. If the washing machine will not empty the water out you may also not be able to open the door on some washing machines although these days it's much rarer to have a pneumatic lock on the door due to cost cutting [ if a washing machine has a pneumatic door safety lock a rubber hose is connected to the door interlock from a pressure chamber bottle on the tub - water in the tub forces air up this tube and locks the door, which is released when the water is pumped out and the air pressure drops].
    Full and detailed advice about finding your pump filter, draining the washing machine when stuck full of water and looking for blockages can be found here - troubleshooting pump faults on a washing machine.
    If this is helpful a vote with the thumbs up would be appreciated for the free advice and is you need furthur explanaition please feel free to contact me .
    Thanks
    Aug 22, 2011 | Samsung Washing Machines
    Zanussie essential 1400 smell of mould can't get rid of it
    g'day. Move the machine to check for leaking water. This could be from the taps in the back, or hose clamps throughout the machine and could be causing chronic dampness around the machine. Also check for filter to clean pump. You might have to look under the machine. The soap draw can also get clogged up - but generally doesn't smell. good luck
    Aug 14, 2011 | Zanussi FC1200W Front Load Washer
    Water won't drain away from the drum. I think I may have a blocked filter. How do I access to clean the filter on a Hotpoint WT960G washing machine please. Many thanks.
    Most Hotpoint washers do not have a customer accessable drain cleanout. Also, it may be a full or partial pump failure. Replacing the pump assembly will improve washer performance.
    Replacement pump is about 20 Pounds delivered, and can be self installed quite easily.
    Link to video
    May 03, 2011 | Hotpoint Washing Machines
    Water pump failure?
    The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
    Remove the drain pump and look for any foreign object to be removed.
    Check the drain pump for a failed pump motor.
    LG is pretty.
    Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
    The water is not draining away. Hotpoint WD63
    filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
    Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    Dan Webster
    Dan Webster
    Sal DeAngelo
