Question about Microwave Ovens
Nn a514abbtq How do you fix the turntable that won't go round
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: Panasonic Inverter NN-A8735 The turntable
Hi, some units use a belt drive to a motor and some use a direct drive motor. You will have to take the case off of the unit and look at the bottom of the unit and see what you have. You should be able to buy a new motor and replace it yourself. There are web sites that specialize in appliance parts. If you can not find one, try a search for "Fox International". They carry a lot of different appliance parts.
Posted on Apr 11, 2011
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Panasonic nn ct766 turntable locked
If everything cooks as normal but the turntable does not turn then I would say that either the turntable motor has failed or the supply for the motor, either way this is not a problem you could fix yourself & so I would recommend taking to a microwave repair centre or service engineer.
Dec 26, 2012 | Microwave Ovens
T783sf sparks from turntable coupling
No it is not safe to use, the windings of the motor are shorting against the coupling, solution! the turntable motor must be replaced in order to resolve the situation.
Jun 19, 2012 | Panasonic NN-T783SF 1350 Watts Microwave...
The round support button under my panasonic microwave turntable is melted. This microwave came with the house so i dont know what happened - probably burning popcorn overheated it. Can i buy this part and...
C Pilutti,
Doing some research, I found parts but you need to call them because there were no pictures to show me what you need and what they have.
This is PartStore Canada
Call 1-866-619-7278
Now also I notice that there are more letters on your microwave Model# so have that ready when they ask you for model #
That number is just behind the door on the left
Thanks
Jul 25, 2010 | Panasonic NN-S542 Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
NN-A574SBBPQ - Microwave fans & turntable not working
2 fuses in a panasonic does not sound enough.
have you checked the main incoming power protection fuse normally 10amp or higher.
most panasonics have approx 4 fuses so keep on looking
Feb 10, 2009 | Panasonic NN-S961 Microwave Oven
Glass turntable
PANASONIC WILL SELL YOU THE PART ALL YOU NEED IS YOUR MODEL NUMBER
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
