Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
Cst2000 handle wiring
Where do you place the sensor switch in the handle so the button is activated when in use
Sears garage door opener wall switch works properly (I do NOT have to hold button in to close door), remotes don't work. Sensors are solid green and door reverses when beam is broken when activate
If you recently changed the light bulb in the unit, try changing it back to a basic clear bulb. I just had the same problem, and after research, found that changing bulb to a new type LED bulb messed up the remotes. A good test, is to try the remotes when the garage door light is "OFF". My remotes worked as long as the light was "OFF". I changed the bulb back to basic bulb, and everything works fine!!
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
How do I remove motor housing on CST2000 Black & Decker weed eater?
If there are no visible screws holding the cover together on the machine, then the parts are snapped into place together, which means much prying, bad talk, aggravation and possible broken parts is next. The manufacturer considers these machines disposable, but they do sell a limited number of repair parts for them. Here is the machine's parts breakdown diagram with parts available list.
http://www.ereplacementparts.com/black-and-decker-cst2000-type-inch-cless-string-trimmer-parts-c-4167_9518_11325.html
Jun 18, 2011 | Garden
My 2000 900ss does nothing when I hit the start button, it is in neutral, battery is charged, what could it be?
Some of those bikes had a bunch of safety switches(read relays) that would go out for no other reason.than to make you really pissed off before you grabbed a hand full of throttle.
The ultimate solution for me and my Yamaha V was to wire the start button to the last relay. Going round the kickstand switch, the brake switch, the clutch switch and the neutral switch. Once the kickstand hits the back of your ankle or the bike jumps with the starter -- you just learned to be a better operator.
First to test the starter; open the handles of a plyers and arc across the big terminals on the starter solenoid. Be in neutral with key off !!!!!!! If starter runs- we are off to the safety switch solution.
So- Hook up a trouble light to your ground on the battery. Get a jumper from the hot side of the starter solenoid. and start going down the row of your safety solenoids. using the light on the output and the hot to activate it. Don't forget- they ground thu their sensor. So- you are testing the solenoid and it's switch(read sensor)- To activate -operate what ever safety devise it is protecting you from. Some where in there will be a dead or open solenoid.
May 26, 2011 | 2002 Ducati 900 SS
It does not turn on even if it was charged for 24 hrs
When it charges, does the red light come on on the charger? Some of the CST2000 chargers make bad connections, and they don't actually charge.
Make sure the red light is coming on when you're charging the battery. If the light is coming on and you still can't use the trimmer after charging, you'll need either a new battery or a whole new battery pack (the black handle of the trimmer).
Hope that helps!
Sep 04, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Have same problem with handle
Same problem here. Anyone able to find this handle or a suitable replacement?? Thx
Aug 20, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
I don't need a manual - I need a replacement handle
if your refering to the batt handle then its a obsolete item with no replacement part number. your part # is 243215-00 and your best bet is to sell it or put lots of ducktape or epoxy or keep checking ebay
Jul 09, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Feb 01, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Hoover Wind Tunnel ON/Off Switch
Replace the rocker switch inside the handle. Part #28161067, it's about $2.50.
Jul 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
43 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
