Question about Peavey Audio Players & Recorders
What is it when a Peavey DPC1400x turns on, plays sound for a split second, makes a buzzing noise, and go us silent
All lights stay on and when amp is silent, lights are green. The fan speeds up when the sound plays and slows down when the amp goes silent. Fuse is fine, I changed it out to a new one
    Sergeant:
  • 238 Answers
The fan is probably thermally controlled. This is done so that there is no fan noise when the volume is low. Once there is sound coming through, if the output stage heats up enough, the fan is turned on. It sounds like one or more of the output transistors is experiencing thermal runaway. The buzzing sound is most likely due to protection circuitry. You would need a schematic and a voltmeter to check this at the very least. If you are not inclined to perform the repair yourself, I would suggest taking it to a local guitar shop that repairs equipment. The smaller shops might have a tech make an initial assessment on the spot, which is something that the big chains are unlikely to do.
Posted on Jun 13, 2014
  • Robert Graf Jun 13, 2014
Thumbsmagee
SOURCE: peavey classic 50/50 keeps blowing fuses.
Rob,
I have a classic 50/50 as well and re-tubed it with JJ el84s, vintage teslas and mullard 12at7s. As long as you replaced it with EL84s, I can't imagine that the output would be increased enough to damage the OT. When I got my 6505 Combo, one of the 6L6s was bad, and it kept blowing fuses and howling like a banshee. I would think that an OT problem would result in a significant loss of output...or none at all. I've gotten DOA tubes from a few places. I would suggest swapping each tube out 1 by 1, until you find it...if that is indeed the problem...before you pay the cash to have it worked on.
Posted on Oct 29, 2007
  • 6 Answers
SOURCE: bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Posted on Nov 08, 2007
robotek
  • 1512 Answers
SOURCE: Peavey KB 300 amp problems
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
regards
Graeme
Posted on Mar 08, 2008
robotek
  • 1512 Answers
SOURCE: peavey xxx stopped working during a show
Hi lespaul 2001
Have you checked your HT fuse. If it fails it will have lights but no sound. Pays to check fuses with a multimeter, as they sometimes look good, but can be dud.
A faulty or intermittent lead speaker box lead will aldo make the head blow fusesCheck the lead to your speaker box also. Dont use a stomp box patch lead. be sure to use a decent speaker lead with quality jacks(switch craft) and at least 16 gauge cable. Ernie Ball make a decent speaker lead for guitar rigs.
If the head keeps blowing fuses, I would suggest that you change you output tubes(4 x 6L6GC). I recommend Electro Harmonix, by Sovtek as a budget conscious option. Get them as a gain matched quartet.
If it does not have a blown fuse at all... then get back to me here and we can do some more tests.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 16, 2008
starlet4life
  • 89 Answers
SOURCE: Peavey Amp manual?
http://www.triodeel.com/tubedata.htm
Posted on Sep 29, 2008
Peavey DPC1400x turns on, plays sound for a split second, buzzes, then goes silent. All lights show green though. What could this be?
This sounds like a power supply capacitor leaking causing a dc bias problem and amp protection shuts it down.
May 06, 2014 | Peavey Audio Players & Recorders
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
When turning the key of my 08 vauxhall zafira a buzzing comes from the cd player, the disc wont stay in or play yet after after 10-15 seconds it stops..radio plays fine also
The buzzing noise is static from the engine, if it does not make the noise when the key is on but engine not running. If so make sure you have a good ground. Most of the time I have found that to be the problem.
Oct 24, 2013 | Vehicle Parts & Accessories
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
Wii makes a horrible noise while loading or ejecting the disc
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Mar 12, 2009 | Nintendo Wii Console
Audio system makes extra noises... pops
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
75 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
