Question about KitchenAid KGSA906PSS Gas Kitchen Range
Why won't the burner in my Kitchenaid gas oven stay lit?
Some water got into it from the top. The control panel asks for a probe temperature even though I have never used a probe or seen that message before. If I enter a temperature the oven will ignite but only for a few seconds before shutting off. It will not ignite again unless I flip the breaker to off and then on. Is this a spark module problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Fro memory these have the igniter pack at the rear of the oven once you get the cooker out it's pretty easy to remove & replace it. If you are unsure ring the manufacturers service division they are usually happy to help.
Posted on May 08, 2014
  • 1314 Answers
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Posted on Jan 24, 2008
SOURCE: KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Posted on Jul 04, 2009
livewire874
  • 618 Answers
SOURCE: KitchenAid Double Oven goes off
The meat probe receptacle may have burned material in it shorting it out or the wires may be shorted.
Posted on Nov 22, 2010
KevinWhite
  • 1902 Answers
SOURCE: hi, i have a kitchenaid
Hello & Welcome to FixYa
Please check this parts image, you will have to test the oven temperature sensor(part#29) and door latch(part#22) before replacing the electronic control(part#33). You can test the temperature sensor first, if it reads between 1080-1120 ohms then it is fine and the electronic control needs replacement. It cannot be the spark module as the stove top works fine and it cannot be the main board as oven and stove top are fine. Please get back to me if you have any other questions.
Kevin
Posted on May 10, 2011
SOURCE: control panel not accepting commands
I too had an issue after cleaning ours. Apparently the water got behind the panel some how. I entered a 3 digit temp(125) and got the oven to start. Turned it off at 250 and all was well. Left the door open about 2" and let the heat dry it out.
Posted on Sep 23, 2012
We have a Chesterfield Cannon double oven (gas) the top oven would not stay lit after holding in the control knob in for several seconds, the engineer came out and fitted 2 new thermocouples but the t
Swap the two thermocouples to see if problem switches. If it does bad thermocouple on one that does not work. If it is the same somethng is wrong with the gas vave itself. The holding coil leading to that burners thermocouple is most likely bad.
Sep 06, 2014 | Heating & Cooling
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
z.doxio
Nov 12, 2013 | Kenmore Kitchen Ranges
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Pilot light is lit both on oven and stove top... previous user says to turn on gas and lite "sensor" or "2nd pilot" it stays lit as long as oven knob is on but oven burner does not light. "sensor" goes out...
On standing pilot ovens the maker uses a safety device to kill the gas in case the pilot blows out. As long as the pilot is lit the gas safety magnet hold the gas flap open inside the safety valve.To save energy the pilot has 2 flames. The standby pilot keeps the cooper/nickel probe/sensor warm so the oven will light faster, the 2nd pilot is much larger, only appears when the oven control is turned on and this is what opens that valve. So when you turn the oven knob on the gas leaves the control and goes downtown to burner land. If that pilot is lit and that slow opening flap inside that valve is open, then the gas will enter the burner tube and ignite when it hits the pilot. Pretty slick ain't it? So what can go wrong? With age the flap inside the safety valve will wear out, get weak, work a little, then take forever to light and eventually just goes bye bye. When you get ready to replace the valve it ain't gonna be adjusted exactamundo, you gotta tweak it. To do so after bubble testing for leaks and lighting the pilot you turn it on and observe the flames. It needs to be not more than half way up the flame spreader. If it is to small of a flame it will take forever to bake even a pie shell, if it is too much their could be burned bottom and in some cases fire hazards. OOPs.
Apr 06, 2010 | Magic Chef 9122 Gas Single Oven
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My electrolux oven won't stay lit
Right above your pilot light, there is a little temperature probe. It either needs to be cleaned, replaced, or adjusted closer to the top of the pilot flame. Hope this helps. Good luck!
Nov 07, 2009 | Cars & Trucks
My gas oven stays warm even though it is turned off
A standing pilot such as this will give off heat. So long as the gas bake burner is not lit also, you will be fine. If the bake burner IS lit you have a defective oven control.
Jun 26, 2009 | GE Ovens
Control panel not accepting commands
sounds as if the meat probe jack is shotring itself. thinks the probe is inserted, adn is lookin to continue on that course. aside form letting it stand and dry out , yo may need to either disconnect or replacethe meat probe jack
Mar 18, 2009 | KitchenAid KERA807P Electric Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
74 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
