Rinex tv Hi, i have a rinex 74cm and The colour on the screen changed to pink,red and black & white.
    Problem Solver:
  • 10 Answers
Yes Jose, this problem very popular! It has to do with degausing the tube. Make sure you dont have any speakers close to your set also.
Its likely you will have to replace the PTC, some models have 2pin and some 3pin. Ciao
Posted on May 30, 2014
Trippynet
  • 47 Answers
SOURCE: help
Not a home repair take it to a repair store.
Posted on Feb 26, 2008
SOURCE: tv has gone wrong
buy new one
Posted on Apr 17, 2008
Shuttle83
  • 1139 Answers
SOURCE: av black and white
Hello boof head,
I got good news and bad news for you. The Hello Kitty TV set uses a Mitsubishi chassis 0707-A20390-00 which employs a single main processor for major systems functions (one of which is color for the AV Composite Video input signal and the Audio input signal. It looks like in your case the processor is bad (IC203). This processor is the sole input for your video signal . The schematic I am looking at shows that from the AV input the signal goes straight to the processor. This processor is tricky because when it goes bad it looks like it could be something else because other devices plugged into the port sometimes works, and misleads folks into thinking that the TV is ok when it is a case of the signal being "hot" enough to leak over into other sections of the chip and causing it to look as though it's working. I would  suggest taking the TV to a qualified repair shop. Now if you don't want to do that you could check the cables and make sure the signal is good going into the AV ports. However that is about the extent you will be able to work on this Tv because of the way it is designed.
I hope this helps
Thank you,
Shuttle83
Posted on May 23, 2008
SOURCE: fly back lines
Check the connector of the crt maybe got a resistor open or a transistor in short circuit.
Posted on Jul 06, 2008
  • 899 Answers
SOURCE: TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Posted on Dec 29, 2008
Why does my galaxy s3 screen turn black, green, or pink?
Screen colours are "additive".
They take some amount of each of the 3 "primary" colours, to make a specific colour. For example, 100% + 100% + 100% gives "white". Getting "pink" when you expect "white" means that you are getting 0% instead of 100% of one of the 3 colours.
Bad screen, or partially-broken cable between the "motherboard" and the screen.
Feb 09, 2015 | Cell Phones
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
Jan 07, 2012 | Alba Televison & Video
The picture on my DVD player is pink! I have tried 3 different DVD players and they are all the same. I have tried adjusting the colour/contrast/brightness etc and nothing is working. The picture is either...
Hi,Would you pls check the connection that you have made between TV and DVD player..?
2xRCA (white+Red) will go to Audio IN sockets of TV in addition to 1xRCA Yellow video cable goes to "Video IN socket of TV..
if the connections are right than you must select the right source on TV ,as AV1 ,AV2 which corresponds to the cable input sockets of your TV.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 11, 2011 | Televison & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Unlocking Logik TV set
If you have child lock on a logic tv. On your remote the bottom where the button is music / sound. Hold in for 5 minutes and the lock will come off
Jul 16, 2008 | Televison & Video
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
Mar 04, 2008 | Televison & Video
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
