Question about RCA F32450 32" TV
Where can one get a flyback transformer for an RCA TV
OTHER PART # ATC 113CA1
    Top Expert:
  • RCA Master
  • 75,581 Answers
Posted on May 07, 2014
tvtek
  • 1284 Answers
SOURCE: RCA D32F750T TV
Did you adjust the two controls on the new flyback? The top one is almost always the focus control and the bottom is the G2/screen control (brightness) If you adjust the G2 do it until the picture looks normal, too high and you will get retrace lines through the picture.
Posted on Jan 26, 2007
  • 45 Answers
SOURCE: rca 36 " F36650
horz output transistor goes out with the fly
Posted on Nov 20, 2007
  • 4234 Answers
SOURCE: RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
Posted on May 29, 2008
ladywinn
  • 5138 Answers
SOURCE: Replaced Flyback Transformer and Horizontal Output Transistor
I am proud to see you got your set working Good job!
Posted on Aug 26, 2008
  • 26 Answers
SOURCE: RCA F32650 32" TV Problem:
The flyback is a a block with some wires coming from it. One of the wire is a big red wire that goes to the picture tube. The FBT is usually on the right rear of the circuit board.
Please be careful when working around the FBT as there are extremely high voltages present - in excess of 25K.
I would suggest you take it to a service shop as when the FBT goes, other parts are usually gone too.
Posted on Nov 17, 2008
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
No picture but i have sound on my RCA F32676SB 32"
You do an adjustment on the screen nob on the flyback transformer?Resolders the CRT-(tv tube) YOKE wires R,G,B connections to the main PCB board?Resolders the video board CRT-(tv tube)video board pins sockets that connect the video board and the CRT-(tv tube) together.
Feb 13, 2011 | RCA F32676SB 32" TV
W to replace the flyback transformer on an RCA rear projection tv
Go to www.tvrepairworld.com you need the 270125 flyback kit listed under the RCA repair kits. The flybackk comes with the CD with step by step instructions.
Apr 06, 2010 | Televison & Video
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
My tv keeps cutting of soon as i turn it on what wrong wit it?
You are in shutdown protect mode, it may be due to a bad flyback transformer and horizontal output transistor, replace both if one is found bad. RCA is nortorious for flyback High Voltage transformer failure.
Dec 21, 2009 | RCA 32F531T 32" TV
No picture no sound just a whistling noise
maybe the flyback transformer or horizontal output ic
Jun 01, 2009 | RCA 27R411T 27" TV
Where can i find Flyback for this Tv
If that is part number 2622341 it is still avaialablr from ther partstore.com
Jun 15, 2008 | RCA 27V530T 27" TV
RCA P52937 Flyback Transformer question
The lead going from the flyback to that other device is a voltage divider or splitter as they're incorrectly referred to... To remove the leads press down firmly, twist and then pull up...
Bill
Nov 21, 2007 | RCA P52937 52" Rear Projection Television
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Oct 17, 2007 | RCA 35V432T 35" TV
Tv will not turn on with remote or when I press the power button on the tv.
The P52960 uses the PTK195 series chassis. The most common cause of that set not starting up is a shorted flyback transformer. It is quite easy to test and replace the flyback transformer in that chassis, but that should be done by a qualified tech experienced in RCA projection sets.
Sep 18, 2007 | RCA P52960 52" Rear Projection Television
RCA F32450 32" TV Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
