Question about Bosch Washing Machines
Bosch Exxcel 1400 will not spin
Bosch Exxcel 1400 (WFO2864GB/01)Why will it not spin? I have replaced the bushes. Checked the pump. Everything else seems ok. This m/c has a spin speed switch that can be used to hold the spin programme-could this be faulty?
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
Posted on Jun 11, 2008
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
Posted on Sep 13, 2009
jonniewalker
  • 1029 Answers
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Posted on Sep 26, 2009
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Posted on Jul 21, 2010
SOURCE: Bosch exxcel 1400 s express fault
F01 Door not closed properly.
F02 Tap not turne on, Inlet hose kinked or pinched, Filter blocked in water inlet hose, Water pressure to low.
Posted on Sep 20, 2010
WFO2864GB/01 will not spin
FIRST IS THE WATER PUMPING OUT WHEN WASH IS DONE AND IT SWITCHES TO SPIN? IF NOT THEN IT WILL NOT SPIN YOU HAVE TO GET RID OF THE WATER FIRST. IF IT IS NOT PUMPING OUT THEN THE PUMP MAY BE THE PROBLEM.
May 06, 2014 | Bosch Washing Machines
My bosch exxcel 1400 express will not spin
take out plug first check the motor carbon brusher are not worn
Dec 03, 2013 | Bosch Exxcel WFX 145S Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch excell 1400 won't drain although the pump is spinning. took all the pipes off before and after the pump cleaned them, drained a couple of times then stopped manually drained it witnessed the pump...
If you are certain that there is no blockage or restriction anywhere and the filter is clear, then I would suggest you replace the pump to solve the problem.
They can work intermittently sometimes,due to wear on the pump impellor.
Jan 30, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
