Question about Sony PlayStation 2 (PS2) Console
My ps2 will not reconize my memory card it says no memory card in slot 1
    Sergeant:
  • 321 Answers
Try blowing into the card and the slot of ur ps2. clean them out
Posted on Jun 22, 2009
  • 18 Answers
SOURCE: PS2 doesn't acknowledge memory card in memory card slot 1
make sure that theres nothing blocking the mem slot 1.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: PS2 Memory card problem
there is an eternal problem get a NEW ps2
Posted on Aug 31, 2008
anjelo_0206
SOURCE: ps2 doesn't recognize memory on slot 1&2
try it on memory slot 2
Posted on Apr 21, 2009
braichizz
  • 12 Answers
SOURCE: my ps2 slim (sliver) just decided to not reconize the memory card
try to push the memory card upwards while inserted...but not to strong...it might break..it happened to my old memory card..
Posted on May 05, 2009
  • 43 Answers
SOURCE: My memory card slot 1(PS2) does not read cards but slot 2 does?
take out slot one memory card and insert your second memory card into it (they are supposed to use slot 1)
Posted on Jan 04, 2010
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
Slot one not reading cards properly.
There isn't way to fix this easily. I recommend taking it to Geek Squad and having them look at it. Although it may be cheaper just to purchase a new Ps2.
Jul 17, 2010 | Sony PlayStation 2 (PS2) Console
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 slim (sliver) just decided to not reconize the memory card
May 05, 2009 | Sony PlayStation 2 Slimline Console
PS2 memory not working on gutiar hero
If it is guitar hero 2 its a known isssue that corrupts the load file, are memory cards madcatz?
Dec 11, 2008 | Sony PlayStation 2 (PS2) Console
Aug 30, 2008 | Sony PlayStation 2 (PS2) Console
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 memory card
Hi Lofatman,
If this problem happens with the memory card when its in either slot 1 or slot 2
I suggest you clean the contacts of the memory card.
If it just happens when you have in Slot 1 or Slot 2 only,
 Go to Radio Shack and get a Can of contact cleaner that has a Brush built into the Spray nozzle.
  1. Turn off the PS2 and disconnect the power cord.
  2. Use a small screwdriver to press open the memory card slot. Do not use too much force, its delicate.
  3. Push the Brush sprayer up into the memorycard slot and spray a little and brush away at the memory slot contacts.
if you do not have success with that, you must open the PS2 case, and Remove the Controler ports and clean up the whole controller port assembly.
If that doesn't work, and your frustrated and not Electronically skilled enough to do this.  I can get the PS2 in tip top shape, for $32 and that includes return shipping.  I run the website www.playstationclinic.com
This should put you in business.
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
