Question about Amana Washing Machines
What does code nd mean? - Amana Washing Machines
  • 641 Answers
Hi Chayna,
"ND" means no drain.The door will not unlock and the unit will not wash or rinse until the water is drained from the washer. You need to pull the washer forward and remove the screws coming into the back panel. Remove the back panel and you can see the drain pump mounted to the floor below the tub. You need to be ready with a wet vac or a lot of towels because the next part is disconnecting the hoses from the drain pump. Make sure the washer is unplugged, then disconnect the hoses and remove the drain pump. Check for any debris in the drain pump. If you find nothing, then replace the drain pump. Otherwise just remove the debris and you'll be good to go again.
Posted on May 06, 2014
What does error code nd mean?
Hello, Vicky -
Is your washing machine a Samsung? If so, "ND" means "No Drain."
Read the information here:
https://removeandreplace.com/2016/03/22/samsung-washing-machine-error-code-nd-what-to-check-how-to-fix/
If I am incorrect in thinking your washing machine is a Samsung, you can Edit your question and add the make and model of your machine, so I or someone else can find an owner's manual for you and check the error codes for your particular machine.
Dec 24, 2017 | Washing Machines
Error code nd
Hi Carolyn,
  • I've looked online. Error code nd could mean 'no drain', but you haven't specified what machine! I suggest that you look online, search "error code nd + your make" .
Jul 17, 2015 | Washing Machines
What does code pf and code nd mean on my amana front load washer mean
PF means power failure and ND means that it did not drain and still has water in it.
Jul 06, 2015 | Amana Washing Machines
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
My Amana washer give a code nd and stop spinning
usually that code means it's not draining.
Feb 13, 2015 | Amana Washing Machines
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
What does nd mean?
The nd refers to NOT DRAINING and the next step may be "he" error which means that no heat will be forthcoming to dry.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Samsung WF203ANW Front Load Washer
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
